HTML editor window not showing
Thread began 10/20/2014 10:43 am by mrs | Last modified 10/21/2014 9:31 am by Jason Byrnes | 3669 views | 11 replies |
mrs
The HTML editor from DataAssist is missing from from the webpage. I have run DataAssist and as a raw page, the editor is missing. I have run DataAssist on a site that also has PowerCMS Builder in it, but the editors for this are showing correctly… just not the DA versions!
Any thoughts?
mrs
See private message for site access if you need to trouble shoot directly
PatriceWebAssist
Be sure you have uploaded all the related WA folders. They don't always get uploaded automatically.
Please give direct links to the pages that show the problem, you give a link to your domain, but no indication of what page i should look at to see the problem.
mrs
Ah yes, now I knew there was more info I need to give, just couldn't think what it was!!
@Patrice: this is happening both locally and remotely.
See below:
see PM
mrs
See below again. Sorry.
on the update page, try commenting the skin. change:
$CKEditor_config["skin"] = "kama";
//$CKEditor_config["skin"] = "kama";
mrs
Yes, that's worked. Thanks. But why is that?
Although it has worked, I have also had to increase margin to the top of the div as it overlaps content above it:
<div class="errorGroup" style="margin-top:70px">
Why is this?
your probably using older copies of both Design Extender for the Power CMS and data Bridge for HTML Editor, there was a conflict in the skins being used before that has been corrected in he latest versions, the different skins also have different heights which is probably the margin issue.
