Clarification on eCart generation
Thread begun 10/20/2014 6:49 am by Christopher West | Last modified 10/21/2014 10:57 am by Jason Byrnes | 5605 views | 15 replies |
Hi I had a few initial questions about usig eCart.
1. If I were to use the server behavior Insert Checkout Form it generates the code that has "eCart Local Checkout" on the checkout page (together with the "checkout with PayPal express button". I noticed that this page errors and located it on line 253:
<tr>
                <td><h3><?php echo(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','First_Name_2')?"Billing ":""); ?>Address</h3></td>
Why would it generate this code since its causing the error?
2. Also with regard to the Insert Checkout Form server behavior. Obviously it generates the code for local checkout and the Checkout with PayPal Express button...but the PayPal Express button is non functioning - what would be the appropriate direction to get this button functioning...since i would require the customer to enter the billing and shipping details from the form on this page (I want to store both billing and shipping details in the website database)...I ask this because using the main eCart Checkout wizard does a completely different approach.
3. Again with the Insert Checkout server behaviour...since it adds the server behaviour "eCart Local Checkout" on the checkout page...would I also place the "Create Email Message" and the "eCart Store Details" and "eCart Store Summary" on this page...or would I still need to place those on a confirm.php file that I need to create? Reason why I ask is that on the main eCart Checkout Wizard the "eCart Local Chceckout" is generated on the confirm.php page rather than the checkout.php page.
I have a few other questions, regarding the Preset Manager with eCart ( may have found a few bugs with with) but wanted to get the above clarified first :
Chris
1) That code is a bug it should not be added, and can be removed. i have logged a bug in our system
2) Inserting the form does not insert any of the server behaviors, you would needs to add the server behaviors needed for express checkout.
on the checkout page you would add the Express Checkout Authentication server behavior, you should also need to create the pp_confirm page and add the Get Payer profile and Process Express Checkout behaviors.
i would suggest running the checkout wizard to create express checkout pages to get familiar with how the pages are put together.
3)
  Again with the Insert Checkout server behavior
you misunderstand that access point, it is not a server behavior, it is only there to insert the checkout form, you need to add the server behaviors to the page that use the checkout form
this includes the create email message, store order summary / details, and the server behaviors to process the cachet through the gateway.
those behaviors are normally added to the conform page.
I have run the checkout wizard and got it stored in a backup project file so I can refer to. but its using a different direction to the main checkout wizard...meaning that the actual server behaviour eCart Local Checkout is on the confirm.php (generated by the main checkout wizard) file not the checkout.php file that its generated using the Insert Checkout form) - this is why i am confused in the 2 different approaches.
Also I have customised the form before running the wizard using the Preset Manager (for example changing city and state form references to town and county) - then after using checkout wizard it does use my new naming references (town and county) but on the confirm page that is generates its still using the default form references (city and state).
Chris
yes, that is the way it is supposed to be.
using eCart -> Insert Checkout Form does not add any of the server behaviors, only the checkout form
you need to add the server behaviors to the page.
the checkout page should have the checkout form
it should post to the confirm page, on the confirm page, you add server behaviors to save the shout form values to session variables.
you add a confirm checkout form and add the local checkout server behavior to process the payment when the confirm button is pressed.
not sure if you got my ammended to my last reply:
you will need to edit the pages after the checkout wizard generates the pages.
I was just wondering why Insert Checkout Form generates the "eCart Local Checkout" server behaviour on the checkout page when it should really be on the confirm.php that i need to create after?
it doesn't, it adds the form only.
On every single test i conducted it generates the local checkout code - attaching file. this is why im getting confused.
I am not able to reproduce. It should not be adding the local checkout behavior.
you should delete it from the checkout page.
