Spry validation with multiple insert & update record
Thread begun 10/17/2014 9:26 am by davegw | Last modified 10/20/2014 9:18 am by Jason Byrnes | 2476 views | 3 replies |
davegw
I've been trying to implement Spry validation with multiple insert & update record server behaviors, but see that only the first row retains the validation. So obviously must rather use server validation - any issues with multiple insert & update record SBs ?
I need to use regexes to validate, and Spry does not play nicely with these.
With Multiple record insert and update, this will take hand coding to accomplish.
We can help set this up in a premiere support appointment:
http://www.webassist.com/premier_request.php
davegw
Thanks Jason - in that case I'll go with a single record insert/update for a table row, then redirect to the same page, until all the records have been entered. Must have either client and/or server validation as the fields must be entered in a fixed format that can only be achieved with a custom regex.
Alternatively could you give me an idea of how to hand-code this on this forum? I realize it's a problem with the runtime dynamic fieldname assignments. I'm quite used to adapting the code in DW server behaviors.
Cheers
Dave
In a multi insert / update scary, the form element names are dynamically generated using a counter
the validation is triggered on the form element names, so the validation code would need to be adapted to use the dynamic form element names.
