Missing first record when looping through array
Thread begun 10/15/2014 3:57 am by CraigR | Last modified 10/16/2014 11:45 am by Jason Byrnes | 4786 views | 9 replies |
CraigRBeta Tester
I am using data from a recordset which I need in json format, but I find that when I loop through the array, the first row is missing from my json encoded page.
The code segment looks like this
mysql_select_db($database_PowerCMSConnection, $PowerCMSConnection);
$query_rscouncil = "SELECT ... FROM tblcontacts ...";
$rscouncil = mysql_query($query_rscouncil, $PowerCMSConnection) or die(mysql_error());
$row_rscouncil = mysql_fetch_assoc($rscouncil);
$totalRows_rscouncil = mysql_num_rows($rscouncil);
while($data = mysql_fetch_array($rscouncil)){
$outputdata[] = $data;
//that gives a multidimensional array, which can then be jsonified:
echo '{ "data":'. json_encode($outputdata)."}";
I know the recordset returns 16 rows, but my jsonified page only contains 15
After playing about with the sort order, it is the first row which is always omitted.
This is something I intend to overhaul with mysqli in future, but I have a set of existing pages I would like to fix
use do while:
do {
} while($data = mysql_fetch_array($rscouncil));
CraigRBeta Tester
Hmm, I tried that, but i get a 'Undefined variable: data' error.
if i set data to empty string, i get 16 rows, but the first one is empty
change the while to:
} while(mysql_fetch_array($rscouncil));
CraigRBeta Tester
that gets me undefined variable data 16 times.
looks like i need to revisit the syntax
try using:
$outputdata[] = $row_rscouncil;
CraigRBeta Tester
no errors, but it returns the same row 16 times !
this should do it:
do {
} while ($row_rscouncil = mysql_fetch_assoc($rscouncil));
CraigRBeta Tester
Thats it !!
Thanks Jason.- appreciated
you're welcome.
