Best eCart practice recommendation
Thread begun 10/14/2014 5:27 pm by Steve | Last modified 10/15/2014 1:16 pm by Jason Byrnes | 4970 views | 17 replies |
Steve
Hello,
I’ d like a suggestion on best practices to check for a product intersection.
Our products have a StartDate and an EndDate saved as a Unix TimeStamp.
The logic for checking if an intersection exists is as follows:
if ($targetEndDate >= $startDate && $targetStartDate <= $endDate)
$showMe = 'trueness';
else
$showMe = 'false';
Our Product page has all the products listed so firing off the validation check on the Product page could be one solution.
The Add to Cart button takes us to the Cart page which looks like an equally viable page to use for checking if there is a clash.
My original logic is to take the first item set to the cart and establish a startDate and endDate, then each newly added product would run the conditional statement as the targetStartDate and targetEndDate. IF an intersection is present we show an alert (show region).
Validation on the Product page would have to block the adding of a new product that clashes but would make it more difficult to remove one item and select another.
Validation on the Cart page seems like it may be the best location to check for clashes but since there is no recordset and the eCart values are sessions, it seems I’d need to pull the productIds from the Session values and then do a comparison.
Before I start programming this , are their any suggestions on the best practices to achieve this goal in eCart (6)?
There isn't early a "best practice" for this, it's custom coding scenario.
Myself, rather than doing validation on the start - end date I would hide items that are not within the range.
If you need help implementing this, please submit a premiere support appointment:
http://www.webassist.com/premier_request.php
Steve
Jason,
Hiding is not a optimal option from a Marketing perspective since the Customer may select a less costly subscription range 1st and then not have the option to select a more costly greater date spanning product if it is hidden. Presenting both and then an alert saying delete one would allow them the freedom to pick which item they would like to retain (on the cart page level).
Is there a way to iterate through the web assist separated session values?
For instance on my cart page I have the following session value containing 3 items and start and end dates for each:
["eCart1_Items"]=>
string(837) "2|WAECART| Next week’s prediction|WAECART|Game predictions for the week. |WAECART||WAECART|0|WAECART|1|WAECART|29|WAECART|1413270000|WAECART|1413874800|WAECART|12|WAECART|14133301714138528|WAECART|0|WAECART|29|WAECART|1 Next week’s prediction (2)
?WA?6|WAECART|Entire Season PROMOTION|WAECART|Game predictions for the ENTIRE season including the playoff games for one low price. Offer expires October 15th. |WAECART||WAECART|0|WAECART|1|WAECART|199|WAECART|1412665200|WAECART|1422864000|WAECART|12|WAECART|141333341205642125|WAECART|0|WAECART|199|WAECART|1 Entire Season PROMOTION (6)
?WA?5|WAECART|All playoff games|WAECART|Game predictions for all playoff games.|WAECART||WAECART|0|WAECART|1|WAECART|29|WAECART|1417507200|WAECART|1422864000|WAECART|12|WAECART|141333341570919962|WAECART|0|WAECART|29|WAECART|1 All playoff games (5)"
Are they like an index? $_SESSION['eCart1_Items'] something to step through the separated values?
use the repeat cart region behavior to loop through the cart and call each column by name, for example this will write each item Name in the cart:
while (!$eCart1->EOF()) {
<?php echo $eCart1->DisplayInfo("Name"); ?>
$eCart1->MoveNext();
$eCart1->MoveFirst();
Steve
Perfect, thank you Jason!
you're welcome.
Steve
Is there a way to count the number of items in the cart using a comparison operator?
<?php if ($eCart1->TotalRows >= 1) {
echo 'Equal or more than 1 ';
TotalRows does not seem to work like it would on a recordset
Steve
This post has been deleted.
This will give the total quantity in the cart.
<?php echo $eCart1->TotalColumn("Quantity"); ?>
Steve
Jason,
Is there a Function that gives a unique Product count? Rather than TotalColumn which gives a total quantity of any existing items.
I tried :
echo '<br> TotalColumn name: '. $eCart1->TotalColumn("Name");
expecting that the TotalColumn function applied to a product title (name) would have returned the count of Products in the cart, but instead returned the name of the Product.
While TotalCount Quantity is really close it will show a single product with 2 items as "2" when the goal is screening for more than "1" Product in the cart.
Thanks for your help!
