PHP Show if...working with two values?
Thread begun 10/14/2014 6:57 am by Nathon Jones Web Design | Last modified 10/28/2014 7:56 am by Jason Byrnes | 5882 views | 15 replies |
I want to display a section of content where the value from one of my recordset fields is not a 6 or a 9.
I am familiar with the Show if column option but am not sure how to adapt it to respond to two values...
<?php if ($row_rsPROD['LEDtypeID'] <> 6) { // Show if column... ?>
<?php } // Show if column... ?>
Would appreciate your advice. Thank you.
NJ
you would need to hand code that using an or statement. in php || is the OR separator
<?php if ($row_rsPROD['LEDtypeID'] != 6 || $row_rsPROD['LEDtypeID'] != 9) { // Show if column... ?>
Hmm...that didn't work and then I noticed some other code on the page that used a double ampersand...
<?php if ($row_rsPROD['LEDtypeID'] != 6 && $row_rsPROD['LEDtypeID'] != 9) { // Show if column... ?>
Maybe US vs UK keyboards at work here. Anyway, it's sorted. Thank you Jason.
NJ
the double ampersand is the AND operator, sorry, i misread your question and should have used AND instead of OR.
Sorry, wee bit of confusion here. I don't think you've misread anything! At the moment I have this:
When the typeID is not either 6 or 9 the "Content" displays. However if I change this to the OR operator, II, then the content does display even if the typeID is 6 or 9? typeID can only be one value so the OR operator seems like the correct choice however it doesn't work.
This product (http://www.ledwarehouseuk.com/LED-Lights-Bulbs.php?lbid=659), for example, has a typeID of 6 yet if I use this:
The "Content" is displayed. Shouldn't it be hidden?
Moving on from the above, can I include another AND or OR clause using a different field from my recordset? I'm trying to cover a scenario where we display "Content" but only if the LEDtypeID is not either "6" or "9" OR LEDid is not "610".
<?php if (($row_rsPROD['LEDtypeID'] != 6 && $row_rsPROD['LEDtypeID'] != 9)) || $row_rsPROD['LEDid'] != 610 { // Show if column... ?>
...but obviously I'd need to sort out the initial issue before proceeding with the above. Hope you can help.
Thank you.
NJ
See PM
Thank you Jason (see below).
I must be missing something. on this product page:
i don't see the cool white or warm white images displaying?
No, they're not. But how is that possible considering that I'm using an AND clause?
If LEDtypeID != 6 AND != 9? It is 6. Shouldn't it be OR?
EDIT: Did I miss something?
This post has been deleted.
