Power CMS Blog
Thread begun 10/12/2014 6:11 pm by Mike Perry | Last modified 10/15/2014 8:07 am by Jason Byrnes | 3714 views | 19 replies |
Mike Perry
Power CMS Blog
I'm using PowerCMS to build a simple blog. Obviously I want the index page to include a listing of the most recent blogs. I wold like the listing to include the title and the first 70 words or so of the post. With the structure of the default cms tables how can I extract the blog title and the blog content to a single record, since they exist in separate records? I can use the ContentPagesetOrder field to tie the two together, but I've been unable to write a SELECT statement that will put them both in one record.
I need the recordset to include both the title and the content. How can I accomplish this??
See this tutorial for details:
http://www.webassist.com/tutorials/Create-new-pages-from-PowerCMS-templates
Mike Perry
This post has been deleted.
Mike Perry
I have two types of ContentRefID -- BlogPostTitle and Content. I also need to include the Content data in the recordset so t hat it is available as a separate field in the same record as the BlogPostTitle. The Results page just pulls the Title. . .
ETA: Think I got it --just modify the Detail page to show the limited Content. Getting the repeating region to work may be tricky. . .
ETA2: Repeating section works fine, if anyone is duplicating this. . .
Glad to hear you have it working.
Mike Perry
Thanks -- another question.
I want to use the Results page to provide a listing of posts for a given month. I've altered the SQL to this:
SELECT C2.ContentGroup, C2.ContentPageSetOrder
FROM pcms2_contents AS C1 LEFT OUTER JOIN pcms2_contents AS C2 ON C2.ContentPagesetParentID = C1.ContentID
WHERE C1.ContentGroup = 'BlogPost' AND C1.ContentDate > d1 AND C1.ContentDate < d2
GROUP BY C2.ContentPageSetOrder
ORDER BY C2.ContentPageSetOrder DESC
adding the ContentDate parameters to the query. d1 and d2 are configured properly and available (returning 2013-04-01 00:00:00 and 2013-06-01 00:00:00 respectively to the results page), but the query doesn't filter the results.
Thoughts??
need more details. i don't see d1 and d2 defined anywhere, how are those defined?
Mike Perry
I didn't post the variable declarations, but here they are
d1
Text
Default -1
$_GET['d1']
d2
Text
Default -1
$_GET['d2]
The variables display correctly on the Results page when echoed. . .
try using:
WHERE C2.ContentGroup = 'BlogPost' AND C2.ContentDate > d1 AND C2.ContentDate < d2
for the where clause
Mike Perry
Still doesn't filter. . .
I have d1 and d2 set to a date earlier than the first ContentDate, and the results page still returns the first record in the db
