Dates not sorting properly...
Thread begun 10/12/2014 11:38 am by Paul | Last modified 4/28/2015 1:45 pm by Ray Borduin | 13913 views | 78 replies |
Paul
Jason,
You helped me sort this data before and it was working perfectly on the home page, as well as the events page. Here is the SQL Statement:
SELECT *
FROM events
WHERE DATE_FORMAT(sort_date, '%Y-%m-%d') >= Date_Format(Now(), '%Y-%m-%d') AND authorize = 1
Not sure if it is the data that is not entered properly on these few events on the home page, but it is out of order. On the events page, it is perfect. Not sure why.
See PM
you need to add an order by clause:
SELECT *
FROM events
WHERE DATE_FORMAT(sort_date, '%Y-%m-%d') >= Date_Format(Now(), '%Y-%m-%d') AND authorize = 1 ORDER BY sort_date ASC
Paul
Jason,
Any idea why it works on one of the pages and not the home page?
Thanks!
because the other page already has the order by clause in place, look at line 61.
Paul
That's interesting because when I go to the Server Behaviors panel and double-click on the Recordset (rsEvents), it doesn't show the "ORDER BY sort_date ASC".
Thanks for your help!
Paul
Hey Jason,
With the records having a start_date and end_date, if I wanted to stop a record from showing on the website based on the end_date (lots of events are more than 1 day, so we want them to show for the entire period but still have the same sorting), how would I manipulate the query below? I've tried a few things, but can't get past the MySQL test in dreamweaver.
SELECT *
FROM events
Thanks!
WHERE DATE_FORMAT(sort_date, '%Y-%m-%d') >= Date_Format(Now(), '%Y-%m-%d') AND DATE_FORMAT(end_date, '%Y-%m-%d') >= Date_Format(Now(), '%Y-%m-%d') AND authorize = 1
Paul
Appreciate this Jason, but it isn't showing any results at all. With the original code, I realized today that some events that are in the admin site in 2015 are not showing up on the live site and some are. I verified that the dates are entered properly (comparing the ones that are showing up to the ones that are not) and they are correct.
Any thoughts would be appreciated.
See PM
Do the ones that are not showing up have an end date value?
if they do not have an endnote set, the query won't return them.
you will need to set an end date.
Paul
I admit, Jason, the person who was entering dates was not putting in the "Sort Date" properly. I just finished going through the entire database and fixing the ones that had the Sort Date incorrect and the website is still maxing out at 69 records. Even after they corrected ones showed up on the site, the total record count was not going past 69.
Thoughts?
