DataBridge compatibility with Dreamweaver CC 2014
Thread begun 10/09/2014 2:31 pm by myron364647 | Last modified 10/29/2014 12:38 am by info4753 | 2660 views | 4 replies |
myron364647
Is the current version of DataBridge 1.2.0 compatible with DreamWeavers CC 2014 release? I upgraded last night to the 2014 version and did a reinstall of the DataBridge extension and now I can't get the extension to load up on an empty PHP page. For example, I created a new PHP file, and saved it. Then go to WebAssist in the menu, and SecurityAssist, then Create Security Pages. The lightbox window will popup for just a moment, then disappear. This happens with any options available under WebAssist. Should I do a clean reinstall again or is there something else? Oh yes, and I haven't even been prompted to reenter the serial number either.
No, there is a bug that we have discovered in the 2014.1 release that is causing problems with the extensions. We are urging people to avoid upgrading if they can
http://www.webassist.com/forums/posts.php?id=35633
we are working on updates to work around the problem and hope to start releasing then next week.
digitaldesign
Hi Jason,
Any word on the Dreamweaver 2014.1 updates release schedule?
Thank you!
Cheers,
Monica
We hope to have an update Data Bridge this week, then will be doing each of the others in turn.
info4753
This post has been deleted.
