Discounts based on users
Thread begun 10/08/2014 2:35 pm by Daniel | Last modified 10/10/2014 12:20 pm by Daniel | 4166 views | 12 replies |
Daniel
Hello,
i'm trying to add some more dynamic aspects to the site. What I'm wanting to do is make a person create an account with us before they are able to make purchases. I was able to create all the pages needed (pretty sure) in the security assist wizard. In the table that was made in the database I added a custom row labeled userapproved which will just have a simple true or false value assigned to it.
Here's what I'm trying to figure out... If the user that is trying to check out has a false value assigned to it, then the person will need to pay full price for the product. If the user has a true value assigned to it under userapproved in the database then I want them to have a 15% (for example) discount on the product.
What I'm not sure how to do is during the checkout process, I'm needing the site to first check to make sure that the user is logged into the site. Then I'm needing the site to check for userapproved in the database to see if it has the true or false value, and make the appropriate adjustments to the price of the books if needed.
Thank you
Use security assist to restrict access to the checkout pages.
in the security assist login behavior, go to the session tab and select to store userapproved column in a session variable.
you can use that session variable as a a discount trigger to apply the discount.
Daniel
To restrict the pages, for example I have for cart.php
grant access if: Logged into ps4_users
if access denied, go to: login.php
Is this what all the pages involving the checkout process needs to be?
Where would I go to have it check that userapproved value for the static book products?
Sorry, i'm a noob at all this as you noticed from my previous post.
Yes, that access restriction should be applied to the checkout pages.
When creating the discount in the cart object, use the based on session variable value trigger to check that the saved session is true.
Daniel
Jason,
I've added a discount named Academia
Separator and Condition
AND (which is grayed out) If Session variable exists: userapproved
Calculations
Based on the cart subtotal
cart subtotal minus .1
It isn't changing the price of the product though. the userapproved is in the table ps4_users that was created when running the security assist pages. I'm not sure if it's checking that table or not looking for a 0 or 1 value for userapproved to enable the discount for the products.
Daniel
This is a dev site that I set up while setting this up. For obvious reasons I didn't want to set this up on the live site.
I have it set up so that you need to be signed into the site with the variable userapproved in the database set to true, Which I'm assuming is a value of 1.
on the login page, lines 74 - 75 and lines 94 - 95 do not have the code to set the user approved session. I edited those lines from:
"sessionColumns" => explode($WA_Auth_Separator,"UserID"),
"sessionNames" => explode($WA_Auth_Separator,"SecurityAssist_UserID"),
"sessionColumns" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."userapproved"),
"sessionNames" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."userapproved"),
perhaps you made the change locally, but it dod not get uploaded to the server.
on the cart page, the display was set up to not show discounts, I added the discount display back in.
NOTE: the discount is set to trigger if the userapproved session is set. you should use the Based on session variable value trigger instead. it will still get set if the value is false in the DB, just set to 0, that's still set though.
Daniel
Jason,
The site is not letting me log in now. I haven't done anything, just hit refresh to test it out. If I do forgot my password it sends me my email and password, but it will not let me log in.
sorry, should be working now, i had accidentally changed the userid session name. i changed it back to SecurityAssist_UserID
