Problem creating RSS feed from PHP/MySQL
Thread begun 8/25/2009 6:36 pm by Travis250923 | Last modified 8/29/2009 8:12 am by Travis250923 | 4131 views | 3 replies |
Travis250923
I'm trying to create a simple RSS feed pulling info from my database. Any idea what's wrong? Any help would be great.
I'm getting this error:
mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Apache2\htdocs\ecochic\rss.php on line 17
This is line 17:
while($row = mysql_fetch_array($data))
This is the full code is:
header("Content-type: text/xml");
echo "<xml version=\"1.0\" encoding=\"UTF-8\">";
echo "
<rss version=\"2.0\">";
echo "
<channel>
<title>Feed title</title>
<description>A description of the feed contents</description>
<link>http://www.ecochicmomma.com/</link>";
require_once("Connections/Conn.php");
// Query database and select the last 10 entries.
$data = mysql_query("SELECT * FROM blog ORDER BY idblog DESC LIMIT 10");
// Continue with the 10 items to be included in the <item> section of the XML.
echo "
<item>
<link>http://www.ecomchicmomma.com/mommatalk_detail.php?ID=".$row[id]."</link>
<guid isPermaLink=\"true\">http://www.ecochicmomma.com/mommatalk_detail.php?ID=".$row[id]."</guid>
<title>".$row[subject]."</title>
<description><![CDATA[".substr($row[entry],0,150)."]]></description>
<comments>http://www.ecochicmomma.com/mommatalk_detail.php?id=".$row[id]."#Comments</comments>
</item>";
echo "
</channel>
</rss>";
Travis250923
So I changed it a bit and get this error:
Invalid query: No database selected
Whole query: SELECT * FROM blog ORDER BY idblog DESC LIMIT 10
Here is the new code. Anyone got any ideas? The Connections/Conn.php is the correct path and is used on other pages to connect just fine to the database. I just don't know why this won't work.
echo "<?xml version=\"1.0\" encoding=\"UTF-8\"?>";
// Set RSS version.
echo "
// Start the XML.
echo "
<channel>
<title>Momma Talk</title>
<description>Momma talk for expectant mothers, experienced mothers and all mothers in between!</description>
<link>http://www.ecochicmomma.com/mommatalk_detail.php</link>";
// Create a connection to your database.
require("Connections/Conn.php");
$query = sprintf("SELECT * FROM blog ORDER BY idblog DESC LIMIT 10");
$data = mysql_query($query);
// Check result
// This shows the actual query sent to MySQL, and the error. Useful for debugging.
if (!$data) {
$message = 'Invalid query: ' . mysql_error() . "\n";
$message .= 'Whole query: ' . $query;
die($message);
// Convert database images data into actual image link.
$row[entry] = str_replace("images/", "http://www.ecochicmomma.com/images/", $row[entry]);
echo "
<item>
<link>http://www.ecochicmomma.com/mommatalk_detail.php?ID=".$row[idblog]."</link>
<guid isPermaLink=\"true\">http://www.ecochicmomma.com/mommatalk_detail.php?ID=".$row[idblog]."</guid>
<description><![CDATA[".substr($row[entry],0,250)."]]></description>
<comments>http://www.ecochicmomma.com/mommatalk_detail.php?ID=".$row[id]."#Comments</comments>
</item>";
// substr can limit the number of characters. First number is starting point while the second number is number of characters.
// otherwise just use $row[entry].
// <guid> is an optional sub-element of <item> but recommended if you don’t want to receive a warning when validating your RSS.
echo "
</channel>
</rss>";
anonymous
Travis,
You need to connect to your database before the query. While I notice, you have a connection script included, that probably just defines the variables. You still need to specify for PHP to connect to the database one line above your query, like this:
mysql_select_db($database_yourDatabase, $yourDatabase);
Now, keep in mind, this is assuming that you've defined variables for your database in that connection script you have included. If not, you'll have to include the database name, user, and password all in the mysql_select_db attributes.
Cheers,
Brian
Travis250923
That was it thanks
