Display page price range
Thread begun 10/06/2014 11:59 am by Patrice | Last modified 10/06/2014 3:30 pm by Patrice | 5745 views | 19 replies |
PatriceWebAssist
Client has 3 price ranges on products but he only wants to show the smallest quantity on the display page instead of the range. Image attached that is photo-shopped to show his request. What do I need to edit in code to limit to just one price, not all? Thanks as always.
looks like your using the grid results payout. so edit the webassist/plugins/catalog/results_grid.php page.
the code that is used to display the price on that page is:
<h3 class="price"><?php if(!($row_WADAProducts["ProductStock"] == 0 && $row_WADAProducts["ProductLive"] != 0 && $row_WADAProducts["ProductUnlimited"] == 0)) { ?>
<?php if( (isset($row_MaxMinPrice['MaxRetail']) && ($row_MaxMinPrice['MaxRetail'] != "") && $row_MaxMinPrice['MaxRetail'] > $ProductPrice)) { ?>
<span class="ProductRetailPrice errorText">Retail Price: <?php echo($WAGLOBAL_CurrencySymbol); ?><span id="ProductRetailPrice" class="strike"><?php echo number_format($row_MaxMinPrice['MaxRetail'], 2); ?></span></span>
<?php } else if ( isset($row_WADAProducts['ProductRetailPrice'] ) && ($row_WADAProducts['ProductRetailPrice'] != "") && $row_WADAProducts['ProductRetailPrice'] > $ProductPrice ){ ?>
<span class="ProductRetailPrice errorText">Retail Price: <?php echo($WAGLOBAL_CurrencySymbol); ?><span id="ProductRetailPrice" class="strike"><?php echo number_format($row_WADAProducts["ProductRetailPrice"], 2); ?></span></span>
<?php } else { ?><?php } ?>
<?php echo($WAGLOBAL_CurrencySymbol); ?><?php
if($row_MaxMinPrice["MinPrice"] > 0) {
echo number_format($row_MaxMinPrice["MinPrice"],2);
} else {
echo number_format($ProductPrice,2);
?><?php echo(($row_MaxMinPrice["MaxPrice"] != $row_MaxMinPrice["MinPrice"])?" - " . $WAGLOBAL_CurrencySymbol . number_format($row_MaxMinPrice["MaxPrice"],2):""); ?><?php } else { echo "SOLD"; } ?></h3>
when there is a price range, it is this part that shows the price:
} else {
PatriceWebAssist
Thanks... but I'm a bit lost. Do I replace the first batch with the second? And please note that ray did some custom for me to show the top line that is tied to "retail" which I don't want to lose.
So, if I am reading this right you are pointing out where the range comes from, not what I should change, correct?
just change:
<?php echo($WAGLOBAL_CurrencySymbol . number_format($row_MaxMinPrice["MaxPrice"],2):""); ?>
PatriceWebAssist
OK... on that page this is what I have:
<h3 class="price"><?php if( (isset($row_MaxMinPrice['MinRetail']) && ($row_MaxMinPrice['MinRetail'] != ""))) { ?>
<span class="ProductRetailPrice">As low as <?php echo($WAGLOBAL_CurrencySymbol); ?><span id="ProductRetailPrice" ><?php echo number_format($row_MaxMinPrice['MinRetail'], 2); ?></span> per lb </span>
<span class="ProductRetailPrice errorText">As low as per lb: <?php echo($WAGLOBAL_CurrencySymbol); ?><span id="ProductRetailPrice"><?php echo number_format($row_WADAProducts["ProductRetailPrice"], 2); ?></span></span>
} else {
?><?php echo(($row_MaxMinPrice["MaxPrice"] != $row_MaxMinPrice["MinPrice"])?" - " . $WAGLOBAL_CurrencySymbol . number_format($row_MaxMinPrice["MaxPrice"],2):""); ?></h3>
starting at line 245
Using this, please tell me what to do... Way over my head. Thanks.
PatriceWebAssist
We posted at same time.... I'm looking again.
PatriceWebAssist
Tried this and got a red warning
} else {
?> <?php echo($WAGLOBAL_CurrencySymbol . number_format($row_MaxMinPrice["MaxPrice"],2):""); ?> </h3>
PatriceWebAssist
thanks
i commented the line:
<?php //echo(($row_MaxMinPrice["MaxPrice"] != $row_MaxMinPrice["MinPrice"])?" - " . $WAGLOBAL_CurrencySymbol . number_format($row_MaxMinPrice["MaxPrice"],2):""); ?>
