Cannot see text in quantity box
Thread begun 10/06/2014 9:29 am by mousework50137 | Last modified 10/06/2014 11:59 am by Jason Byrnes | 2956 views | 7 replies |
mousework50137
Hi
Added my first product to the store but cant see the text in the quantity field on the products detail page or shopping cart as text appears to be white in a white cell.
How can I change the colour of the text appearing in these cells,
see
http://weavingmachinery.co.uk/products_detail.php?ProductID=1
Thanks for anticipated help
http://weavingmachinery.co.uk/webassist/themes/Weaving%20Machinery/css/default_styles.css
edit:
.productDetailWrapper .addToCart form input#WA_Store_Cart_1_Quantity_Add {
font-size:11px;
padding:5px;
width:40px;
font-size:11px;
padding:5px;
width:40px;
color: #000000;
mousework50137
Thanks Jason,
That sorted the detail page but not the cart where the quantity field still has white text,
AND (Sorry)
Just noticed that the text in the categories box is also white and can't be seen.
If you go to www.weavingmachinery.co.uk, then select Drills from the products you will see what I mean.
Is this a quick fix also?
in the default css, you have the base color defaulting to white:
body, h1, h2, h3, h4, h5, h6, p, #cssmw, dl, dt, dd, form, input {
color: #ffffff;
you can change the base color there, or edit the following selector:
.contentBox .productResultsWrapper .description {
margin-bottom: 5px;
min-height: 25px;
to change only the description.
you can use firebug:
http://www.webassist.com/tutorials/Using-Firebug
to inspect elements on your page and find CSS that is effecting them, that is what I am using to find these for you.
mousework50137
Hi jason
I have changed
margin-bottom:5px;
min-height:25px;
to
margin-bottom:5px;
min-height:25px;
color:#000000;
but text is still white,
Feeling a little bit of a numpty, what am I doing wrong?
I used firebug and it said change line 375 in the default_styles.css
I don't want to loose the white out text on the home page inside the three pods
try creating a new selector as:
.contentBox .productResultsWrapper .description p {
color:#000000;
mousework50137
Thank you so much,
sorted.
you're welcome.
