Security assist help
Thread begun 10/06/2014 8:40 am by russb335115 | Last modified 10/09/2014 8:37 am by Jason Byrnes | 5030 views | 13 replies |
russb335115
Is it possible to prevent certain email address from registering on a website?
Example: I don't want anyone with an @yahoo.com or @gmail.com to be able to register as a user.
you could hand code a check for the email address filed:
if(isset($_POST['email'])) {
$emailArray = explode("@", strtolower($_POST['email']));
if(is_array($emailArray)) {
if(in_array("yahoo.com", $emailArray) || in_array("gmail.com", $emailArray)) {
header("Location: pageName.php?badDomain=true");
this will redirect to page called pageName.php with a badDomainURL variable
use an if statement to show an error message if the bad domain uRL = true:
<?php if(isset($_GET['badDomain']) && $_GET['badDomain'] == "true" ) { ?>nope<?php } ?>
you can of course edit the page name in the code.
russb335115
Great,
Thank you Jason,
you're welcome.
russb335115
This code goes on the register page?
The first part goes before the Head tag?
The second part is attached to the email field?
yes, the first part goes at line 1, the second snippet where you want the error to display.
russb335115
Well I think I have it right but not getting the results. If you have a moment can you check it out: (see pm)
on your page the name of the email element is:
Registration_group_4_Email
did you edit the code to use the correct form element name?
you will need to change:
$_POST['email']
$_POST['Registration_group_4_Email']
russb335115
Still not working, do I need to also change this: $_POST['Registration_submit']
