Which one is missing?
The code that sets the pins on the map is in the map file:
image: new google.maps.MarkerImage('plugins/webassist/google_javascript/images/pushpin_deepjungle.png', new google.maps.Size(40,41), new google.maps.Point(0,0), new google.maps.Point(7,38)),
shadow: new google.maps.MarkerImage('plugins/webassist/google_javascript/images/pushpin_shadow.png', new google.maps.Size(40,41), new google.maps.Point(0,0), new google.maps.Point(7,38)),
you can change that to use your own images.
to prevent the default info window opening, you can remove the following code:
// open info window for default address
if (isDefault) {
infowindow.open(map2,marker);
setTimeout("google.maps.event.trigger(wagmp_map_2_obj.markers[" + wagmp_map_2_obj.markers.length + "], 'click')",1000);
//map2.setCenter(point);
It is not supported to open on hover rather than click, but require editing this code:
google.maps.event.addListener(marker, 'click', function() {
for (var x=0; x < wagmp_map_2_obj.infowindows.length; x++) {
wagmp_map_2_obj.infowindows[x].close();
to change the listener.
