Edit Multiple Updates behaviour to only update one field
Thread begun 9/29/2014 10:35 am by iainmacdonald331081 | Last modified 9/30/2014 7:33 am by Jason Byrnes | 2435 views | 5 replies |
iainmacdonald331081
I have a page with a Multiple Updates behavior applied which is updating two fields - one a checkbox, and one a text field.
I now need it to only update the text field.
I can't see the behavior listed in the Server behaviours panel to edit, and have looked at editing the code directly.
In the attached file, the fields are:
AY_africa_winner (checkbox, no longer needed)
AY_africa_rank (text field, still needed)
I've done this sort of thing before without problems, but keep going wrong here.
The file is as it was now, but I tried taking out the reference to AY_africa_winner on line 139.
And changing lines 140, 147, 148 and 152.
I assume I'm going wrong with the none, none NULL parts.
Presumably this is a straightforward enough edit, and I don't need to redo the whole thing?
Thanks.
change line 138 - 140:
$WA_fieldNamesStr = "AY_africa_winner|AY_africa_rank";
$WA_columnTypesStr = "',none,''|none,none,NULL";
$WA_fieldNamesStr = "AY_africa_rank";
$WA_columnTypesStr = "none,none,NULL";
and line 147:
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("AY_africa_winner", $WA_multipleUpdateCounter)
."" . $WA_AB_Split . "".WA_AB_getLoopedFieldValue("AY_africa_rank", $WA_multipleUpdateCounter)
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("AY_africa_rank", $WA_multipleUpdateCounter) ."";
iainmacdonald331081
Thanks Jason - that's pretty much what I was trying, but isn't working. Its fine with the original with the two fields, but with that it doesn't update the AY_africa_rank field.
I have attached an updated version, with more info below.
Probably easiest to recreate the page then
iainmacdonald331081
Thanks Jason - I spotted what was breaking it. I had commented out the input field for the field I didn't need to update, and had also commented out the hidden field for the tables ID column.
Uncommenting that fixed it.
ok, glad to hear it is working.
