Installing PowerGallery
Thread begun 9/27/2014 1:02 pm by hdavis136190 | Last modified 10/07/2014 8:34 am by Jason Byrnes | 4521 views | 15 replies |
hdavis136190
I loaded url kodakorner.info/testing/PowerGallery the first time, it went through the checks on version/permissions page them serial number entry, told me I had invalid code entered, I entered a I instead or 1 when I reentered the correct code (the 1) the I now get
I get kodakorner.info/testing/PowerGallery/install_gallery/database.php 404 error, if I put that file back it gets deleted and that error shows. What do I do to move forward?
hdavis136190
ok
I updated the install_gallery/database.php to fix the problem, attached is a copy of the updated file.
hdavis136190
images/installed.png gets deleted
Thanks, After entry of all correct database information, I now get the error below, and that installed.png file is not there, I put the file back, load the main page again, file is deleted.....
Warning: require_once(images/installed.png) [function.require-once]: failed to open stream: No such file or directory in /home/content/16/7558216/html/testing/PowerGallery/admin_gallery/global.php on line 32
Fatal error: require_once() [function.require]: Failed opening required 'images/installed.png' (include_path='.:/usr/local/php5/lib/php') in /home/content/16/7558216/html/testing/PowerGallery/admin_gallery/global.php on line 32
i updated the admin_gallery/global.php file to fix the problem
hdavis136190
Thanks, now when adding a new gallery, when I goto pick the Design I get this:
Warning: opendir(../galleries/) [function.opendir]: failed to open dir: No such file or directory in /home/content/16/7558216/html/testing/PowerGallery/admin_gallery/choosedesign.php on line 48
In the private message section, please provide the power gallery admin login so I can reproduce to troubleshoot.
hdavis136190
ok
the PowerGallery/galleries/ folder was missing from your site, i uploaded the folder to fix the problem.
