Using 2 results on one page, 'delete' not playing nicely
Thread began 9/16/2014 5:38 am by Jamie | Last modified 9/30/2014 9:00 am by Jason Byrnes | 2500 views | 7 replies |
Jamie
Hey Jason
Have got to results on the attached page. If you hit delete on one of them, if the other has got an id of the same value then it also gets deleted. What have I done wrong to cause that to happen?
Cheers
Jamie
Both forms have the same Delete button name. and both delete behaviors are triggered on Button: Delete pressed.
edit each of the delete buttons to use a unique name, and edit each of the delete behaviors to trigger on the corresponding uniquely named delete button.
Jamie
have renamed them as:
<input type="submit" value="Delete" class="formButton" id="Delete" name="DeleteScroller" />
and
<input type="submit" value="Delete" class="formButton" id="Delete" name="DeleteSlideshow" />
i have also updated the triggers
if (isset($_POST["DeleteScroller"]) || isset($_POST["DeleteScroller_x"])) // Trigger
and
if (isset($_POST["DeleteSlideshow"]) || isset($_POST["DeleteSlideshow_x"])) // Trigger
do I need to change anything else - reason I ask is that both delete buttons now delete the scroller content so have clearly done something incorrectly
(file is attached)
message me through skype tomorrow and I will look into this with you.
Jamie
Hey Jason
Was trying to apply the changes we made to the above to another page that I was experienicng the same issue with (attached) and its nto working.
When I say its 'not working' regardless of which delete button is clicked nothing gets deleted.
Cheers
Jamie
at line 114 and 145, you have both behaviors set to use the same delete button as the trigger:
if (isset($_POST["Delete"]) || isset($_POST["Delete_x"])) // Trigger
but, one of the delete buttons is named DeleteSlideshow and the other is named DeleteScroller
you will need to edit the code for the triggers to use the correct button names.
Jamie
you da man!!! as ever many thanks mate
Jamie
you're welcome.
