File upload with Relational Table
Thread begun 9/15/2014 11:34 am by danielsebas | Last modified 9/15/2014 11:48 am by Jason Byrnes | 1107 views | 1 replies |
danielsebas
Hi, I used the manage realtional table behavior for inserting and updating pictures, but when I apply the file upload behavior nothing happens. No file is uploaded. The behavior looks like this:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "imagenes/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["cambiar"]) || isset($_POST["cambiar_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "foto_1_".$RepeatSelectionCounter_1 ."", "2", "[NewFileName]_[Increment]", "false", $WA_UploadResult1_Params);
// WA DataAssist Manage Relational Table 1
if (isset($_POST["cambiar"]) || isset($_POST["cambiar_x"])) // Trigger
$WA_arrayOrFieldList = 1;
$WA_joinLoopedField = "item_id";
$WA_loopedField = "WADA_RepeatID_fotoItemID";
$WA_connection = $musicosEC_CONN;
$WA_table = "fotos";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_masterKeyField = "foto_bandID";
$WA_masterKeyType = "none,none,NULL";
$WA_masterKeyValue = "".$row_rsBanda['bnd_id'] ."";
$WA_masterKeyComp = "=";
$WA_joinedKeyField = "foto_fotoItemID";
$WA_joinedKeyType = "none,none,NULL";
$WA_joinedKeyComp = "=";
$WA_fieldNamesStr = "foto_bandID|foto_1|foto_fotoItemID";
$WA_columnTypesStr = "none,none,NULL|',none,''|none,none,NULL";
$WA_appliedString = "";
$WA_appliedList = array();
$WA_valuesList = array();
$WA_connectionDB = $database_musicosEC_CONN;
if ($WA_arrayOrFieldList == 0) {
$WA_loopedValues = $_POST[$WA_joinLoopedField];
for ($v=0; $v<sizeof($WA_loopedValues); $v++) {
$WA_fieldValues = "^MASTERID^" . $WA_AB_Split . "".WA_AB_getLoopedFieldValue("foto_1", $WA_mrtLoopCounter) ."" . $WA_AB_Split . "^JOINID^";
$WA_valuesList[] = array($WA_loopedValues[$v], $WA_fieldValues);
$WA_appliedString .= "^" . $WA_loopedValues[$v] . "^";
$WA_appliedList[] = $WA_loopedValues[$v];
else if ($WA_arrayOrFieldList == 1) {
$WA_mrtLoopCounter = 0;
while (WA_AB_checkLoopedFieldsExist(array($WA_loopedField), $WA_mrtLoopCounter)) {
if (WA_AB_checkLoopedFieldsNotBlank(array($WA_joinLoopedField), $WA_mrtLoopCounter) && WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter) == WA_AB_getLoopedFieldValue($WA_joinLoopedField, $WA_mrtLoopCounter)) {
$WA_valuesList[] = array(WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter), $WA_fieldValues);
$WA_appliedString .= "^" . WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter) . "^";
$WA_appliedList[] = WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter);
$WA_mrtLoopCounter++;
WA_AB_doManageRelationalTable($WA_valuesList, $WA_appliedString, $WA_appliedList, $WA_connection, $WA_table, $WA_masterKeyField, $WA_masterKeyType, $WA_masterKeyValue, $WA_masterKeyComp, $WA_joinedKeyField, $WA_joinedKeyType, $WA_joinedKeyComp, $WA_fieldNamesStr, $WA_columnTypesStr);
if ($WA_redirectURL != "") {
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "-1";?>
// WA DataAssist Pre-Select Relational Table 1
$WA_PreSelect_RelationalTable_1 = array();
$WhereObj = WA_AB_generateWhereClause(array($WA_masterKeyField), array($WA_masterKeyType), array($WA_masterKeyValue), array($WA_masterKeyComp));
$WA_Sql = "SELECT ".$WA_masterKeyField.", ".$WA_joinedKeyField." FROM ".$WA_table." WHERE ".$WhereObj->sqlWhereClause." ORDER BY ".$WA_joinedKeyField;
$WA_mrtJoinRS = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
if (mysql_num_rows($WA_mrtJoinRS) > 0) {
while ($row_WA_mrtJoinRS = mysql_fetch_assoc($WA_mrtJoinRS)) {
$WA_PreSelect_RelationalTable_1[] = $row_WA_mrtJoinRS[$WA_joinedKeyField];
File upload is not compatible with multiple insert / update or the manage relational table behavior.
using manage relational table, or multiple insert / update, the form element names become dynamically created, the file upload behavior will not work in this instance because it does not support dynamically naming the element name.
it will take hand coding to make this work, we can help set this up through a premiere support appointment:
http://www.webassist.com/premier_request.php
