DataAssist not deleting the correct record from a repeating region
Thread begun 9/13/2014 5:46 am by acaciasd344844 | Last modified 9/19/2014 8:19 am by Jason Byrnes | 3126 views | 5 replies |
acaciasd344844
Using dataAssist 2.1.0. DreamWeaver CS3 MySQL 5.0.10 PHP 5.4 Windows XP Pro
I am a bit baffled here, I have a repeat region that displays a record set of different food products. I have also inserted a button next to the product name within this repeat region so that when a button is clicked it should delete the appropriate record by the record ID number. But, what is actually happening is, that it is deleting the last record in the repeating region and unfortunately not the one I selected. I have hunted everywhere on the page to see what I am doing wrong but I just cant see it. Hope you can help. John
you need to add code to the submit button to set a hidden element to the selected ID
create a hidden form element on the page named deleteID, make sure deleteID is used for both the name and ID of the hidden element.
then edit the submit button to add an onclick event to set the deleteID:
<input name="deleteproduct" type="submit" class="custom_button_red" id="deleteproduct" value="-" onClick="document.getElementById('deleteID').value=<?php echo $row_Recordsetfindallprodid['johnsid']; ?>">
then in the delete record behavior, set the delete ID to use the deleteID hidden element.
acaciasd344844
Hi Jason,
Hope all is well, thanks for that, I will give it a go right now.
John
you're welcome.
acaciasd344844
Hi Jason,
I gave the button code another go but yet again its doing the same thing, deleting the last record in a list rather than the one selected. I followed your instructions by adding the following code
<input name="deleteID" type="hidden" id="deleteID" value="<?php echo $row_Recordsetfindallprodid['purchaseid']; ?>">
<input name="deleteproduct" type="submit" class="custom_button_red" id="deleteproduct" value="-" onClick="document.getElementById('deleteID').value=<?php echo $row_Recordsetfindallprodid['purchaseid']; ?>">
then amending the server behavior to point at the deleteID hiden element as shown below
<?php echo((isset($_POST["deleteID"]))?$_POST["deleteID"]:"") ?>
As I say I have tried numerous other attempts, but to no avail. It will not select the correct record id for deletion. I have tried it with hidden elements and text fields. I'm beginning to think it may be down to the MySQL code that is attached to the repeat region.
I did try something I created a temporary field and pointed it at the purchase recordid, then i created a simple link 'testlink' and pointed that at the same page and the temporary field. similar to the following.
page_4.php?tmp=<?php echo((isset($_POST["tmp"]))?$_POST["tmp"]:"") ?>
When hovering the mouse over the link, their is no value visible.
page_4.php?tmp=
So if no value is being sent to the server, I guess the delete behavior is just deleting the last record in the database table. I have had issues with the isset($_POST function before, so could that be the culprit, it is posting even though the variable is empty.
I'm not sure Jason, I'm no php developer at all
Thanks again
John
