Database issues on a few files
Thread begun 9/11/2014 2:52 pm by Daniel | Last modified 4/26/2016 11:41 am by Ray Borduin | 11458 views | 73 replies |
Daniel
I'm in the process of setting up a basic store, but I'm getting errors on a few of the pages that are all relatively the same. I havent't done any changes to anything. I've just tried previewing the page in the browser to see what it looks like. following the step by step guide, it suggests you do so to get a look at what it's looking like so far after it is created.
Warning: mysql_select_db() expects parameter 2 to be resource, object given in D:\xampp\htdocs\summitlt\includes\_detail.php on line 40
Warning: mysql_query() expects parameter 2 to be resource, object given in D:\xampp\htdocs\summitlt\includes\_detail.php on line 42
I'm getting this same general thing on a few pages. I tried inserting a product and got this as well for the insert.php page (or whatever it is called).
Thank You
Daniel
Right now it's set up locally. I was having issues getting the data assist to connect to the server.
Daniel
I've put it online. Of course now it's showing up as a blank page whereas doing it locally would show the error.
See PM
Daniel
PM
what specific page should i be looking at, you give a very general site address, i don't see a problem on the first few links i clicked, please be more specific.
Daniel
It's doing it on all of the pages that try talking to the databas that was made by the Web Assist products.
http://fryedevelopment.com/includes/_insert.php
http://fryedevelopment.com//includes/products_results.php
For instance when trying to insert a new product on insert.php it's referring to these line codes.
product results: Undefined variable: totalRows_WADAproducts with code
$queryString_WADAproducts = sprintf("&totalRows_WADAproducts=%d%s", $totalRows_WADAproducts, $queryString_WADAproducts);
and also mysql_select_db() expects parameter 2 to be resource, object given with two lines of code
mysql_select_db($database_Summit, $Summit);
and
$WADAproducts = mysql_query($query_limit_WADAproducts, $Summit) or die(mysql_error());
also with the products_results.php page.
Your using a MySQLi connection.
Data Assist is not compatible with MySQLi yet. we are working on upgrading Data Bridge to use MYSQLi, but at this time it will will only work with a standard MySQL connection
Daniel
Is there an easy fix to this? Or should I start over with it since I haven't done that much.
