what is the new code for the following
Thread begun 9/09/2014 12:42 pm by The Flying Fox | Last modified 9/17/2014 9:23 am by Jason Byrnes | 1856 views | 3 replies |
The Flying Fox
I have sessions based on the older sql
@session_start();
if(!($totalRows_rsCoupons == 0)) {
$_SESSION["PromoAmount"] = "".$row_rsCoupons['couponAmount'] ."";
What would be the new code based on MySQLi if the recordset is not empty.
This does not appear in the eCart / General / set session value if using the newer MySQLi recordset
I've tried the following code.
@session_start();
if(!($rsCoupons->num_rows == 0)) {
$_SESSION["PromoAmount"] = "".($rsCoupons->getColumnVal("couponAmount")) ."";
But it does not seem to work
correct code would be:
@session_start();
if ($rsCoupons->TotalRows > 0) {
$_SESSION["PromoAmount"] = "".$rsCoupons->getColumnVal("couponAmount")."";
The Flying Fox
Thanks Jason.
you're welcome.
