Trying to use eCart binding in a switch statement
Thread begun 8/25/2009 9:36 am by Dave Buchholz | Last modified 8/25/2009 11:41 am by Jason Byrnes | 1637 views | 1 replies |
Dave BuchholzBeta Tester
I am trying to print a minimum qty depending on the value of $eCart2->DisplayInfo("Description") and I have set up my switch statement as follows:
echo '<br /><span class="minqty">Minimum Quantity = ';
switch($eCart2->DisplayInfo("Description")) {
case 'Postcards':
//do something e.g. echo();
echo '50';
break;
case 'Stickers':
//do something else e.g. echo();
echo '25';
break;
default:
// default behaviour if all else fails e.g. echo();
echo '12';
echo '</span>';
But regardless of the value of $eCart2->DisplayInfo("Description") it defaults to 12, what am I doing wrong ?
the values where being returned with an extra space at the end, for example "Stickers " instead of "Stickers"
We changed the switch statement to use the trim function to strip the spaces:
switch(
trim($eCart2->DisplayInfo("Description"))) {
case
'Postcards':
echo '50';
break;
case
'Stickers':
echo '25';
break;
default:
echo '12';
echo
'</span>';
