Broken column sort
Thread begun 9/08/2014 9:43 am by iainmacdonald331081 | Last modified 9/08/2014 12:40 pm by Jason Byrnes | 2622 views | 5 replies |
iainmacdonald331081
Broken column sort - caused by URL form?
I have some pages that are using a session to make up part of the URL, and have noticed that since doing that the column sort has stopped working.
I have attached a copy of the page and details below - first of all, should the sort still be able to work with the URL of the form:
http://www.mywebsite.com/myfolder/index.php?CategoryID=7
Thank you.
your sort link need to include the category
your sort is working by passing the sort URL variable:
sort=2015_Awards_Participant
where you are passing in the category as another URL variable:
CategoryID=7
you need to concatenate the 2:
CategoryID=7&sort=2015_Awards_Participant
so fior example, the link would need to look like this:
<a href="index.php?CategoryID=<?php echo(isset($_GET['CategoryID'])?$_GET['CategoryID']:""); ?>&sort=2015_Awards_Participant">
iainmacdonald331081
Thanks Jason - I added updated links to the status, votes and average score columns - the URL looks correct, but it doesn't look like its sorting?
It looks like the sort server behavior was added for the WADAlodges recordset which has been removed from your page and replaced with the rsLodges recordset.
edit the sort server behavior, and assign it to the rsLodges recordset.
iainmacdonald331081
Thanks Jason.
you're welcome.
