Fatal Error: Function name must be a string
Thread begun 8/25/2009 8:52 am by tom92909 | Last modified 9/15/2009 10:43 am by Jason Byrnes | 12382 views | 5 replies |
tom92909Beta Tester
Good morning! :)
I've created a new shopping cart using the new 4.5 eCart Extension. I've had v4 working in the past with no issues, but this is a brand new cart using the the new version.
On order confirmation, I'm getting the following error message;
Fatal error: Function name must be a string in /public_html/confirm.php on line 306
Line 306
$WA_fieldValuesStr = "".session_id()  ."" . "|" . "".((isset($_POST["email"]))?$_POST["email"]:"")  ."" . "|" . WA_eCDB_ConvertNumber("".$eCart1->GetShipping()  ."") . "|" . WA_eCDB_ConvertNumber("".$eCart1->GetTax()  ."") . "|" . WA_eCDB_ConvertNumber("".$eCart1->GrandTotal()  ."") . "|" . "".$date(m/d/Y)  ."" . "|" . "".((isset($_POST["firstname"]))?$_POST["firstname"]:"")  ." ".((isset($_POST["lastname"]))?$_POST["lastname"]:"")  ."" . "|" . "".((isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"")  ."";
I have Dreamweaver CS3.
I am using Apache, Linux PHP, and MySQL.
I have probably 7 other domains with functional v4 carts (not v.4.5)
I am populating both Order and OrderDetail tables when the transaction is completed.
confirm.php - Lines 297 thur 357:
// WA eCart Store Cart Summary in Db
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) // Trigger
$WA_connection = $ba;
$WA_table = "orders";
$WA_redirectURL = "";
$WA_indexField = "OrderID";
$WA_fieldNamesStr = "OrderReferenceID|OrderUserID|OrderShipping|OrderTax|OrderTotal|OrderDate|OrderUserName|ip_address";
$WA_columnTypesStr = "',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''";
$WA_sessionName = "eCart1_OrderID";
$WA_Sql = "";
$NeedInsert = false;
$indexFieldIndex = -1;
$WA_fieldValues = explode("|", $WA_fieldValuesStr);
$WA_columns = explode("|", $WA_columnTypesStr);
$WA_connectionDB = $database_ba;
$updateFieldValue = "";
mysql_select_db($WA_connectionDB, $WA_connection);
  if (!
session_id()) session_start();
  if (
$WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos('?', $WA_redirectURL) === false)?"?":"&").$_SERVER["QUERY_STRING"];
$WA_fieldNames = explode("|", $WA_fieldNamesStr);
  for (
$i = 0; $i < sizeof($WA_fieldNames); $i++)
    if (
$WA_indexField  == $WA_fieldNames[$i])
$indexFieldIndex = $i;
      break;
$deleteFieldValue = "";
$updateColType = "none,none,NULL";
  if (
$indexFieldIndex >= 0) $updateFieldValue = $WA_fieldValues[$indexFieldIndex];
  if (
$updateFieldValue == "" && isset($_SESSION[$WA_sessionName])) $updateFieldValue = $_SESSION[$WA_sessionName];
  if (
$indexFieldIndex >= 0) $updateColType = $WA_columns[$indexFieldIndex];
  if (
$updateFieldValue != "")     {
$updateParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, $indexFieldIndex);
$valueForWhere = WA_generateInsertParams(array($WA_indexField), array($updateColType), array($updateFieldValue), -1);
$WA_Sql = "update " . $WA_table . " SET " . $updateParamsObj->WA_setValues . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues;
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = $updateFieldValue;
$result = mysql_query("SELECT * FROM " . $WA_table . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues, $WA_connection);
$num_rows = mysql_num_rows($result);
$NeedInsert = (mysql_num_rows($result) === 0);
  if (
$updateFieldValue === "" || $NeedInsert)  {
$insertParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "insert into " . $WA_table . " (" . $insertParamsObj->WA_tableValues . ") values (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
  if (
$WA_redirectURL != "")  {
header("Location: ".$WA_redirectURL); exit;
Any suggestions?
I think I see the problem. You have the date code as:
$date(m/d/Y)
it should be:
$date("m/d/Y")
change line 306 to:
$WA_fieldValuesStr = "".session_id()  ."" . "|" . "".((isset($_POST["email"]))?$_POST["email"]:"")  ."" . "|" . WA_eCDB_ConvertNumber("".$eCart1->GetShipping()  ."") . "|" . WA_eCDB_ConvertNumber("".$eCart1->GetTax()  ."") . "|" . WA_eCDB_ConvertNumber("".$eCart1->GrandTotal()  ."") . "|" . "".$date("m/d/Y")  ."" . "|" . "".((isset($_POST["firstname"]))?$_POST["firstname"]:"")  ." ".((isset($_POST["lastname"]))?$_POST["lastname"]:"")  ."" . "|" . "".((isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"")  ."";
tom92909Beta Tester
Yes. That helped.
Thank you.
Excellent, glad to hear it.
joczan389207
I am having Trouble with something similar.
I am trying to create a php script for an online form, and the following appears:
Fatal error: Function name must be a string in D:\Hosting\3560291\html\contactformprocess.php on line 9
My code is the one below, can someone tell me whats wrong with it?
/* Subject and Email Variables */
$emailSubject = 'September 19th registration!';
$webMaster = 'cesct@ntplx.net';
/* Gathering Data Variables */
$emailFiled = $_POST('email');
$nameField = $_POST('name');
$phoneField = $_POST('phone');
$addressField = $_POST('address');
$hearField = $_POST('hear');
$travelersField = $_POST('travelers');
$commentsField = $_POST('comments');
$body = <<< EOD
<br><hr><br>
Email: $email <br>
Phone: $phone <br>
Address: $address <br>
How did you hear about us?: $hear <br>
How many will be attending?: $travelers <br>
Comments: $comments <br>
EOD;
$headers = "From: $email\r\n";
$headers .= "Content-type: text/html\r\n";
$success = mail($webMaster, $emailSubject, $body, $headers);
/* Results rendered as HTML */
$theResults = <<< EOD
<html>
<head>
<title>Connecticut Educational Services</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<style type="text/css">
body {
background-color: #f1f1f1;
font-family: Verdana, Arial, Helvetica, sans-serif;
font-size: 12px;
font-style: normal;
line-height: normal;
font-weight: normal;
color: #666666;
text-decoration: none;
</style>
<head>
<div>
<div align="left">Thank you for your interest! Your email will be answered very soon!</div>
</div>
</body>
</html>
EOD;
echo "$theResults";
your syntax for referring to form elements is not correct.
needs to be changed to:
$emailFiled = $_POST['email'];
$nameField = $_POST['name'];
$phoneField = $_POST['phone'];
$addressField = $_POST['address'];
$hearField = $_POST['hear'];
$travelersField = $_POST['travelers'];
$commentsField = $_POST['comments'];
