Receiving Error - Data Assist Results Page - HelperPHP.php
Thread begun 9/05/2014 9:48 am by dlovas275157 | Last modified 9/09/2014 8:22 am by Jason Byrnes | 3464 views | 7 replies |
dlovas275157
Parse error: syntax error, unexpected T_STRING in D:\Inetpub\hunterbooks\WADbSearch\HelperPHP.php on line 181
Appears to be caused by this include in the header of my dataassist results page
//WA Database Search Include
require_once("../../WADbSearch/HelperPHP.php");
Attached is my HelperPHP.php file if that helps.
Thanks.
Dan
dlovas275157
See PM
i updated the WADbSearch/HelperPHP.php file to fix the error.
dlovas275157
Great! Thanks.
you're welcome
dlovas275157
Jason,
I have recently received the same error on other sites built with WA.
Can you explain why I would be getting these same errors all of the sudden? Was there a recent PHP upgrade that the older file was not compatible with?
HEre is an updated copy of the WADbSearch/HelperPHP.php file that you can use on your other sites to fix the error.
I cant say why it was working before and started not working now, the syntax error that is being reported should have been showing before, All i can do is send a file to fix it.
