fatal error
Thread begun 9/04/2014 11:34 am by tkendrickmail32213 | Last modified 9/04/2014 12:12 pm by tkendrickmail32213 | 4812 views | 6 replies |
tkendrickmail32213
fatal error
I am getting the following error on my power gallery on the following page http://southcarolinagolfcarts.net/golf-cart-gallery.php:
Warning: mysql_pconnect(): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/southcar/public_html/powergallery/Connections/powergallery.php on line 9
Fatal error: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/southcar/public_html/powergallery/Connections/powergallery.php on line 9
this error means the mysql host name in the connection file is not correct.
Double check with the host for the correct address to use for connecting to the MySQL server.
tkendrickmail32213
I haven't changed anything. what is the file I need to change? powergallery.php? I can login just fine, so the database is working.
you need to edit the Connections/powergallery.php file.
if this was working before and just recently started giving an error, you should contact the host for details.
tkendrickmail32213
I found that file. they are still using localhost as the hostname. What is the next option? Remember, I can login still to the admin area. So, the database is connected.
I dont see an error on that page, see attached screen shot.
maybe try clearing the browsers cache.
Where I cant reproduce this error, I don't believe it haw anything to do with the code.
tkendrickmail32213
looks like it was having server issues for a while. thanks,
