Setting up tax for 1 state
Thread begun 9/03/2014 12:43 pm by Ericspecullaas | Last modified 2/12/2026 8:08 am by Sam Barnhart | 3839 views | 8 replies |
Ericspecullaas
Greetings I am setting up a tax rate for CA but I dont the CA tax rate to apply to other states in the ecart1_PHP file i have this code
if (true && (((isset($_SESSION['eCartCheckoutForm_state_province'])?$_SESSION['eCartCheckoutForm_state_province']:"") != "CA"))) {
and it give me the tax rate but when I change it to this
if (true && (((isset($_SESSION['eCartCheckoutForm_state_province'])?$_SESSION['eCartCheckoutForm_state_province']:"") == "CA"))) {
or even this
if (true && (($this->GetTaxableTotal() > 0) && ((isset($_SESSION['WASF_CheckoutWizard_Basic_Default']['State'])?$_SESSION['WASF_CheckoutWizard_Basic_Default']['State']:"") == "CA"))) {
it hides the tax field no matter what and i get nothing added to the Grand Total section. It also doesnt presist to the checkout page as well
thanks!
Ericspecullaas
PM sent
Need more information, see PM
Ericspecullaas
replyed I should double check what i copy next time.
a var_dump of the session shows the state is in a session named:
[WASF_CheckoutWizard_NewFromBlank_Default']['State']
so the code for the trigger rule should be:
if (true && (($this->GetTaxableTotal() > 0) && ((isset($_SESSION['WASF_CheckoutWizard_NewFromBlank_Default']['State'])?$_SESSION['WASF_CheckoutWizard_NewFromBlank_Default']['State']:"") == "CA"))) {
Ericspecullaas
ok it worked but what i had to do was throw away the WA_eCart folder and rebuild the cart from scratch and add the rules back in.
thank you Jason Byrnes
you're welcome.
Sam Barnhart
Help needed w/ adding state tax for just 1 state
Jason, Hi.
Ive been trying to reach out but not sure my entries are making thru. Sorry if you get many.
Any help would be greatly appreciated. See priv comm
