Snow Leopard
Thread begun 8/25/2009 5:53 am by support294769 | Last modified 8/25/2009 2:19 pm by Ray Borduin | 3291 views | 3 replies |
support294769
Snow Leopard
Are the extensions compatiable with Snow Leopard?
Also, if I have dwcs3 and cs4 on the same mac machine will that cause extension issues via the extension manager?
1) Most things are compatible with snow leopard, but some things like google maps and possibly paypal standard does not work on Snow Leopard for reasons outside of our control. Search this forum for issues reported on Snow Leopard, we don't delete posts and this is the only entry point for reporting problems, so you can easily research known issues here.
2) Two versions of DW should not cause issues.
anonymous
Ray,
Thanks for clarifying. And just to understand the issue further, will WebAssist work on making extensions like Google Maps Pro compatible with Snow Leopard in either dot releases or new releases of the extension?
Many thanks,
Brian
When possible we will, but in some cases the limitations in the browser or service are the cause of the issue and there isn't much we could work on. That is the case for google maps pro in particular. Google would have to fix the problem and it wouldn't be something we could work on.
