ecart 'add to cart' not showing MySQLi recordset
Thread begun 8/31/2014 7:11 am by The Flying Fox | Last modified 9/17/2014 9:23 am by Jason Byrnes | 5299 views | 9 replies |
The Flying Fox
I am in the process of updating my store to using MySQLi instead of the older version.
My new recordset will not show (grayed out) on the add to cart option from eCart - I have the new ecart extension 6.0.8 and MySQLi 1.0.2 installed.
Am I jumping the gun a little too quickly? I did believe the new release was compatible with MySQLi.
Andy
Can you test the recordset successfully?
If you open the bindings panel, and expand the recordset, does it show the column bindings?
have you tried resetting the workspace layout:
Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
The Flying Fox
Hi Jason,
Tried all four, recordset tried and works for 1 and 2
Reset workspace and deleted cache
Also created a new page and new recordset, no other data on page and tried to add to cart button, same results
Andy
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
The Flying Fox
Hi Jason,
I am also having problems with my contact form
Please see attached.
This was working before I reset my pc, not since the reboot It doesnt work...not validating Captcha and not sending the email.
please see attached php file
Andy
I have sent a skype contact request.
The Flying Fox
Hi Jason,
I have uninstalled and reinstalled all my extensions.
Add to cart now seem to be working ok
But I get an error Call to undefined function htmlentites() on my page (right clicking and selecting view source), this stops the page from loading correctly.
The generated form code from the extension reads as
<form name="CHG_cart_1_ATC_<?php echo($rsProduct->getColumnVal("ProductID")); ?>" method="POST"
action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlentites($_SERVER["QUERY_STRING"]):""; ?>">
I changed the action of above to
action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>"
And this seems to work with the page loading correctly and adding to cart is now functioning.
Is there a reason that the first code snippet does not work correctly?
Andy
It's a syntax error.
htmlentites
should be:
htmlentities
I have logged a bug for this.
The Flying Fox
Thanks Jason
you're welcome.
