Rule to show text if no record found
Thread began 8/28/2014 1:54 pm by iainmacdonald331081 | Last modified 8/29/2014 8:35 am by Jason Byrnes | 1216 views | 5 replies |
iainmacdonald331081
I have a bit of text on a page to display a list of categories from a table, if the query returns any results using:
Allow if <?php echo $row_rsNominations['ScoreID']; ?> <> ''
But what would the rule be to display some text (e.g. 'This lodge has received no votes yet') if there are no matching records in the query?
I guess as there are no matching records I can't compare any fields - but presume this must be possible?
Use the Show If recordset is empty server behavior.
iainmacdonald331081
Thanks Jason - I thought there was one like that, but had misplaced it as I hadn't reinstalled the mySQLi extension after issues with the Extension Manager. (Although it might be somewhere else, pre mySQLi?)
So I have that reinstalled, and trying:
WA > mySQLi > Show Region > mySQLi Show If Recordset Is Empty / mySQLi Show If Recordset Is Not Empty
But I'm getting the error:
Before you using this server behavior, please create a recordset.
Even though the page does have recordsets. Copy attached below.
your recordset is a standard MySQL recordset, so you need to use the standard show if recordset is not empty, not the MySQLi one.
iainmacdonald331081
Thanks Jason - my mistake there was looking under WA for it - forgot it was one of the regular DW ones.
Although weirdly didn't want to work in code view, which was throwing up a message about having to select something first.
But was fine in design view.
yeah, the show if behavior doesn't work correctly in code view.
glad to hear you have it working.
