datepicker display selected day of week on different area of page
Thread begun 8/27/2014 2:56 pm by Jason | Last modified 8/28/2014 12:33 pm by Jason | 13784 views | 9 replies |
Jason
I'm trying to using datepicker in a form to insert a date in my database formatted as a MySQL date but I also need to display the day of the week for the selected date in a different area of my page. How can I show only the selected day (Monday, Tuesday, etc..) in another area?
I Don't follow, please provide more details
Jason
For example, after selecting a date in the datepicker it displays Thursday, August 28 2014. I want to display "Thursday" after another field in the same form.
Similar to what google calendar does when you are creating a weekly recurring event and you select Wednesday. At the bottom it would say "repeats every week on Wednesday".
This would require hand coding, I Found an example of this through google here:
http://www.danielmayor.com/jquery-get-day-of-week-from-jquery-ui-datepicker-when-we-select-a-date
but we do not offer support for this through the forum. if you nee help implementing this, I suggest a premiere support appointment:
http://www.webassist.com/premier_request.php
I Put together a quick example using the linked page:
<!doctype html>
<html>
<head>
<meta charset="UTF-8">
<link type="text/css" href="webassist/datepicker/untitled1_datepicker_1/jquery-ui.css" rel="stylesheet" />
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
</script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
$(function(){
$('#datepicker_1').datepicker({
dateFormat: 'mm/dd/yy',
showAnim: 'show',
onSelect: function(dateText){
var seldate = $(this).datepicker('getDate');
seldate = seldate.toDateString();
seldate = seldate.split(' ');
var weekday=new Array();
weekday['Mon']="Monday";
weekday['Tue']="Tuesday";
weekday['Wed']="Wednesday";
weekday['Thu']="Thursday";
weekday['Fri']="Friday";
weekday['Sat']="Saturday";
weekday['Sun']="Sunday";
var dayOfWeek = weekday[seldate[0]];
$('#dayOfWeekSpan').html("You selcted "+dayOfWeek+"");
onClose: closeDatePicker_datepicker_1
function closeDatePicker_datepicker_1() {
var tElm = $('#datepicker_1');
if (typeof datepicker_1_Spry != null && typeof datepicker_1_Spry != "undefined" && test_Spry.validate) {
datepicker_1_Spry.validate();
tElm.blur();
</script>
</head>
<body>
<input id="datepicker_1" name="test" type="text" />
<span id="dayOfWeekSpan"></span>
</body>
</html>
if you need further help adapting this, please submit a premier support request:
Jason
Once again YOU DA MAN!! Thanks! That was exactly what I needed.
you're welcome.
Jason
I know I'm pushing my luck here but I have one more question on this thread.
Is it possible to assign a value to the text in the span, and then submit that value with my form?
For example, if "Wednesday" was displayed in the span it would have a hidden value of 3, and 3 would be entered into a specified column of my database when the form was submitted.
I didn't know if something like this would work in the function or not.
weekday['Wed']="Wednesday" value="0";
that would require further custom coding that is not supported.
Jason
Ok, thanks.
