Store and Keep Session when record set is updated
Thread begun 8/27/2014 9:32 am by mycalidesigns | Last modified 8/27/2014 10:33 am by Jason Byrnes | 1894 views | 3 replies |
mycalidesigns
I have a page were I am passing a form variable and storing as session variable when directed to new page. I have a recordset that uses a GET function to update table. When the recordset is updated on the same page i loose my session.
How do i keep my session when updating a recordset and staying on the same page. The recordset has nothing to do with session.
send you page please so i can see the code.
mycalidesigns
Jason, always thanks for you prompt response greatly appreciated. I have a form that passes a variable to page i attached. The issue is on this page i have a recorded that updates when client picks a certain option.
Two issues
1. the form on step-2-session.php passing the value doesn't update the Session $_SESSION['totalguestcount'] on the menu-items.php page
2. $_SESSION['totalguestcount'] on menu-items.php gets lost when recordset is updated based on $_GET function from links
I attached both pages.
step-2-session - menu-times.php
1) the form element on the step 2 session page that passes the guest count is named fieldset_group_Select_One:
<select class="formMenufield_Medium" name="fieldset_group_Select_One" id="fieldset_group_Select_One" rel="<?php echo((isset($_GET["invalid"])?ValidatedField("testguests","fieldset_group_Select_One"):"")); ?>" tabindex="1" title="Please enter a value">
2) the form on that page is set to use the post method:
<form class="NewFromBlank_Default" id="Default_NewFromBlank_Default" name="Default_NewFromBlank_Default" method="post" action="menu-items.php">
3) on the menu items page, you have 2 pieces of code to set the guest count session:
@session_start();
if("" == "") {
$_SESSION["totalguestcount"] = "".$_GET['totalguestcount'] ."";
session_start();
// store session data
if (isset($_SESSION['totalguestcount']))
$_SESSION['totalguestcount'] = $_POST['fieldset_group_Select_One']; // or if you have any algo.
the first one should be removed since the get wont pass the selected value, it will be passed by the post.
in the second one, you should use the fieldset_group_Select_One post element as the trigger:
session_start();
if (isset($_POST['fieldset_group_Select_One'])) {
