Looking up a field value to include in an email
Thread begun 8/27/2014 8:15 am by iainmacdonald331081 | Last modified 8/27/2014 12:25 pm by Jason Byrnes | 1674 views | 5 replies |
iainmacdonald331081
I have a page used to add a record to a table, which also triggers an email.
The table structure includes:
nominations
NominationID (PK)
CategoryFullID (FK)
etc
categoriesFull
CategoryID (PK)
Category
etc
The form is adding a record to the nominations table, including the field CategoryFullID.
I would like the email to include the Category field for the CategoryFullID in the form, but can't pull it directly from a form value, as the form is only adding the CategoryFullID, and not referencing the Category itself.
I have had a stab at it, by trying to
- store the CategoryFullID value in a session (CategoryValue) when the form is submitted.
- use a query (rsCategories) to return the record from the categoriesFull table where the CategoryID = the value stored in the session.
- echo the Category value fro that record in the email.
I hope that makes sense - I'm sure it must be possible, even if my attempt is all wrong!
Copy of the file and other details below.
in your private message, you don't include a link, I'm pretty good at figuring stuff out, but i have no idea which index.php page in your site is the one that you are having the problem with .
one thing i do notice with the file that you sent me, is the UE code block uses a file named webassist/email/waue_index101_1.php fo the settings, but I don't see that file on your server:
include("../webassist/email/waue_index101_1.php");
please give a link to the page so i properly troubleshoot.
iainmacdonald331081
Sorry Jason - was the wrong site details - have amended them above. The webassist/email file should be wake_index_nomination_category.php
the select list for the category is named Parent:
<select name="Parent" id="Parent" onchange="WA_FilterAndPopulateSubList(Child_WAJA,MM_findObj('Parent'),MM_findObj('Child'),0,0,false,': ')">
your code to set the session:
$_SESSION["CategoryValue"] = "".((isset($_POST["CategoriesFullID"]))?$_POST["CategoriesFullID"]:"") ."";
refers to a form element named CategoriesFullID which does not exist on the page, it should be edited to use the Parent form element instead.
iainmacdonald331081
Thanks Jason - that's working now.
you're welcome.
