ISSUE: Overides DW CS6 "Dynamic" Select options with Classic ASP
Thread begun 8/27/2014 7:27 am by Nick Green | Last modified 8/27/2014 1:46 pm by Jason Byrnes | 1236 views | 1 replies |
Nick Green
I've just found an issue. We still use Classic ASP for some sites due to there being MSSQL Databases in place. However, we have just gone back into a Classic ASP site and then clicked on a Select form variable and then clicked on "Dynamic" as the options are derived from a database. The MySQLi WebAssist behavior then pops up!
I though that this was just for PHP MySQLi sites, but it has seemed to overwrote the DW function for sites that don't need MySQLi etc.
can someone advise the best approach? It would seem silly to have to uninstall the behavior every time we wish to switch to a Classic ASP site and then turn on for MySQLi sites.
Nick
It will still work work with the classic ASP recordset.The Recordset Select list should still list the classic ASP recordset, choose that recordset and the dynamic list code will be generated using classic asp code.
Our UI just checks to see if the connection is a MySQLi connection. If not, it applies the behavior the way Dreamweaver would have.
