Disounts applied to individual products when bought in bulk
Thread begun 8/27/2014 2:33 am by jon392819 | Last modified 8/28/2014 7:43 am by Jason Byrnes | 1666 views | 3 replies |
jon392819
Jason, you very kindly helped me get my discounts working. We are applying discounts based on QTY. Break points dictate the discount. Works great. Below is the formula we used and the attached shows my next problem.
(abs([Quantity] >= 6 && [Quantity] < 12)?([Price] * [Quantity]) * 0.05:0) +.............. etc
The problem I have is when two or more variations of the one product are added to the cart. The discount is applied line by line. Is it possible to have the discount applied to the product as a whole, including the size variations etc. The screen shot shows the problem well. One product in the cart with two variations. The discount needs to be applied to the 15 fleeces and not just the first ten. Hope this makes sense.
If I didn't have any clients I think life would be so much easier :)
Theres not a way to do that in the cart object, it would require hand coding to accomplish.
you would need to create a cart loop, look at each ID line by line and if the id matches add the quatity of the 2 together, then calculate the discount.
This kind of custom coding is beyond the scope of this support forum, we could help you implement this in a premiere support appointment:
http://www.webassist.com/premier_request.php
jon392819
Understand Jason, do you think an hour would do it?
Should be able to do this in an hour, but i can't make any promises.
