how to bypass merchant checkout if due to coupon cart amount total is $0
Thread began 8/21/2014 3:22 pm by john42771 | Last modified 8/22/2014 6:47 am by Jason Byrnes | 362 views | 1 replies |
john42771
I have coupon code that basically gives the product to the customer free of charge.
It seems unnecessary for them to have to enter their credit card info in order to complete the checkout process and pay nothing.
What solution do you recommend?
use the checkout wizard to create another set of checkout page using no gateway, make sure to use unique names for the new pages
then on the cart display page, add code to the checkout redirect code block which will look like:
//WA eCart Redirect Check Out
if (isset($_POST["eCart1_Checkout"]) || isset($_POST["eCart1_Checkout_x"])) {
$Redirect_redirStr="checkout.php";
if ($Redirect_redirStr != "") {
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") === false) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "Checkout";
NOTE: this code was generated for an eCart object named eCart1, yours may look different.
change this line:
to check the grand total and change the checkout redirect if it is 0:
if($eCart1->GrandTotal() > 0) {
} else {
$Redirect_redirStr="free_checkout.php";
again,, this code is for a cart object named eCart1, if your is named differently, you will need to adjust accordingly.
