MySQLi while loop for recurring event calendar
Thread begun 8/21/2014 12:13 pm by Jason | Last modified 9/02/2014 5:24 pm by Jason | 4933 views | 7 replies |
Jason
Hey Jason,
I'm still working on the same page kids_insert_shift_recurring.php, but now I'm trying to get my insert to work correctly.
What I'm going for here is to have the insert behavior write 1 row for every time the event would occur into the kids_programs_shifts table of my database and then stop after 1 year of events have been written.
For example if I created a recurring event for Jan 1st and said it should recur every month on the 1st day. When I hit submit it should write 11 or 12 (not sure if it's going to count the originally created event or overwrite it) events into the kids_program_shifts table and then stop.
Here's what I got so far, but I ain't having much luck.
if ((((isset($_POST["Submit"]))?$_POST["Submit"]:"") != "")) {
$next_event = strtotime($_GET["Frequency"].' '.$_GET["RecurType"].' FROM '.$_POST["RecurStart"]);
while(date('Y-m-d', $next_event)<strtotime('1 year from '.$_POST["RecurStart"]) && date('Y-m-d', $next_event)<strtotime($_POST["RecurEnd"])){
$InsertQuery = new WA_MySQLi_Query($local_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "kids_program_shifts";
$InsertQuery->bindColumn("kids_program_date", "t", "".((isset($next_event))?$next_event:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
echo $InsertQuery->Statement;
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
// $InsertQuery->redirect($InsertGoTo);
$next_event = strtotime($_POST["Frequency"].' '.$_POST["RecurType"].' FROM '.$next_event);
This is more advanced custom coding than i can help with here in the forum, you should sign up for a premiere support appointment where we can work with you in a one on one session:
http://www.webassist.com/premier_request.php
Jason
Yeah I was afraid of that. No room in the budget for it at the moment. I'll try to keep plugging away at it for now. Thanks anyway!
Jason
Hey Jason,
I know you said I was going to have to submit a premier support ticket for help with the recurring events calendar, but I think I've figured it out except I'm having one last issue. I'd love to post a working generic version of all the files to the forum when I'm done for others to use. The last issue doesn't really have anything to do with your products, but it does seem to be a simple php problem. I've had a lot of help from people I know here to get this far, but everyone seems to be stumped on this and I thought you might be willing to take a look and work your magic if I published a complete working version to the forums since I've seen a lot of request for it in the past.
The calendar is on the index page and on line 39 it gets the event data from the events page. If you view the source of events.php it's putting out the correct data string, however the calendar on index.php only displays the first event in each recurring event. The really strange thing is the if I copy the source output of events.php and paste it at the end of the events.php source code (and comment out the render_fccalendar_events(); function), the calendar displays the recurring events correctly. From what I can see it's the index page is getting exactly the same string either way, but obviously something is different.
If you're not able to provide support on this issue I completely understand. Just thought I'd ask.
i'm not sure, rely, this is beyond what I can offer support for.
however, looking at the source of events.php, it looks like the first 2 event gets ID 1, then each one after it gets ID 2:
[{"id":"1","title":"92575","start":"2014-08-01","end":"2014-08-01","allDay":"","editable":"1","repeat_i":"1","repeat_f":"3","repeat_e":"2023-04-13"},{"id":"1","title":"77727","start":"2014-08-22","end":"2014-08-22","allDay":"","editable":"1","repeat_i":"1","repeat_f":"3","repeat_e":"2023-04-13"},{"id":"2","title":"51794","start":"2014-08-04","end":"2014-08-04","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"82558","start":"2014-08-06","end":"2014-08-06","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"86149","start":"2014-08-08","end":"2014-08-08","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"28106","start":"2014-08-10","end":"2014-08-10","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"49485","start":"2014-08-12","end":"2014-08-12","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"65132","start":"2014-08-14","end":"2014-08-14","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"11004","start":"2014-08-16","end":"2014-08-16","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"37249","start":"2014-08-18","end":"2014-08-18","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"67753","start":"2014-08-20","end":"2014-08-20","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"56621","start":"2014-08-22","end":"2014-08-22","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"25915","start":"2014-08-24","end":"2014-08-24","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"43782","start":"2014-08-26","end":"2014-08-26","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"},{"id":"2","title":"72648","start":"2014-08-28","end":"2014-08-28","allDay":"","editable":"1","repeat_i":"0","repeat_f":"2","repeat_e":"2023-04-13"}]
seams to me that each event should get a unique ID, no?
Jason
No, according to the fullcalendar documentation recurring events all need to have the same ID. I went down that path myself though, and manually set the id's. It didn't change anything. Check these 2 pages all I did was copy the output of events.php and pasted it at the bottom of the source code (essentially feeding index.php the same info), but this time the calendar displays the correct information. I changed the date on these to Sept, but just because I got tire of clicking back to August. I produced the same result as when they were August though.
It's not a package i am familiar with, so really cant offer support.
Jason
Ok. Thanks for taking a look anyway!
