Insert Record - Remove spaces and replace with dashes and increment it not unique
Thread begun 8/21/2014 11:41 am by dlovas275157 | Last modified 8/21/2014 1:32 pm by Jason Byrnes | 3357 views | 7 replies |
dlovas275157
I am working on a permalink solution, and in order to do so I plan to create unique strings based on another database field.
Ex:
DB Field | Value
careerId: 1
careerTitle: Senior Sales Associate
careerPermalink: senior-sales-associate
I would like when I insert the record for the DataAssist insert server behavior to take the same form field and insert it twice, the second time with any spaces removed and replaced by dashes to accomplish the above data.
Im using <?php echo strtolower(((isset($_POST["careerTitle"]))?$_POST["careerTitle"]:"")) ?> to make it all lowercase, but do not know how to replace spaces with dashes or handle the increment.
Is there a way to easily accomplish this with DataAssist / DataBridge?
use str_replace()
<?php echo strtolower(((isset($_POST["careerTitle"]))?str_replace(" ","-",$_POST["careerTitle"]):"")) ?>
dlovas275157
Jason,
Thanks. That worked great.
Now the more complex part - how can I insert a "-1" at the end if there is already an entry for "Senior Sales Associate", or insert a "-2" if there are already 2 entries for "Senior Sales Associate", and so on?
Upon insert, I would need to check the database for matching entries in the careerTitle database field, count them and add increment if needed in the compiled careerPermalink database field.
Or maybe i just need to make sure the "careerPermalink" field is unique and increment it if needed? No sure how to do this.
Appreciate any further help.
Daniel
create a recordset to count the occurrences:
SELECT count( * ) AS occuraanceCount
FROM products
WHERE ProductName = paramPost
in the variables section create a new variable as:
type: text
default value: -1
run time value: $_POST["careerTitle"]
than concatenate the recordset value:
<?php echo strtolower(((isset($_POST["careerTitle"]))?str_replace(" ","-",$_POST["careerTitle"]).(($row_recordsetName["occuraanceCount"] > 0)?$row_recordsetName["occuraanceCount"]:""):"")) ?>
dlovas275157
Jason,
Again that worked great. Thank you!
I tried to modify it to make the increment "-2" instead of just "2" but cannot seem to get it right. Can you help with this last mod.
senior-sales-associate2
senior-sales-associate-2
<?php echo strtolower(((isset($_POST["careerTitle"]))?str_replace(" ","-",$_POST["careerTitle"]).(($row_rsOccurrencePermalink["occurrenceCount"] > 0)?$row_recordsetName["occurrenceCount"]:""):"")) ?>
<?php echo strtolower(((isset($_POST["careerTitle"]))?str_replace(" ","-",$_POST["careerTitle"]).(($row_rsOccurrencePermalink["occurrenceCount"] > 0)?"-".$row_recordsetName["occurrenceCount"]:""):"")) ?>
dlovas275157
Perfect! Thank you again for the prompt help.
-DL
you're welcome.
