Checkout Wizard - Orders Tab not Working
Thread begun 8/21/2014 9:13 am by keith505 | Last modified 8/21/2014 10:50 am by Jason Byrnes | 3067 views | 6 replies |
keith505
I am using eCart 6.08 on Windows 8.1. When I click on the "Orders" tab in the Checkout Wizard, and then click to "Define" the Orders table or the Order details table, the window pops up and is blank. I can define and test the connection. It was working earlier today, but the presets would always default to my "category" table even though the fields listed were from a different table. So, something was odd from the start. I have since uninstalled and reinstalled eCart. Really need help with this as I am trying to finish up a project. Thanks!
keith505
Forgot to say that I am using DW CC
Try restarting windows, and clearing the cache from the users configuration folder:
keith505
This did not help. I removed the WinCache file and rebooted. Restarted DW and then started the wizard again. Same results. When I close window, I see the attached.
Looks like that is a bug when trying to edit the presets, I will get this logged in our system to be corrected in the next update, for now, you should use the presets as they are, and make any necessary changes to the server behaviors on the confirm page after the pages are created.
keith505
What if I already have the order tables. I don't want the presets to try to create new tables.
IF the order and order details tables already exist, it will try to use those tables, but if there are structure differences, the code wont be created correctly.
you would be best at this point to use the tables created by the wizard, then make any necessary updates to those tables after they are created.
