MySQLi insert issues
Thread began 8/20/2014 11:25 am by Steve | Last modified 8/22/2014 6:39 am by Jason Byrnes | 4773 views | 14 replies |
Steve
Trying to update a prior working INSERT but not having any errors from the MySQLi Insert behavior to see why it will not work.
Note the uploads an image (works) and then the INSERT redirects as if things went well (no errors) but there is no record created.
Here;s the code that does not work:
<?php require_once('../Connections/minBlog_i.php'); ?>
<?php require_once('../webassist/framework/framework.php'); ?>
<?php require_once('../webassist/framework/library.php'); ?>
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
$rsType = new WA_MySQLi_RS("rsType",$minBlog_i,0);
$rsType->setQuery("SELECT * FROM tblinvtype WHERE tblinvtype.mid = 2 AND tblinvtype.status = '0' ORDER BY tblinvtype.typeName");
$rsType->execute();
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../uploadedImg/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "800",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'FileName' => "thumb_[FileName]",
'ResizeWidth' => "350",
'ResizeHeight' => "",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_2 End
// WA_UploadResult1_3 Start
$WA_UploadResult1_Params["WA_UploadResult1_3"] = array(
'UploadFolder' => "../uploadedImg/small/",
'FileName' => "_thumb2[FileName]",
'ResizeWidth' => "220",
'ResizeHeight' => "120",
// WA_UploadResult1_3 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "imageUp", "0", "", "true", $WA_UploadResult1_Params);
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$InsertQuery = new WA_MySQLi_Query($minBlog_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "test";
$InsertQuery->bindColumn("field", "s", "".((isset($_POST["Title"]))?$_POST["Title"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("fieldtwo", "s", "".((isset($_POST["event"]))?$_POST["event"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("sess_news");
$InsertQuery->execute();
$InsertGoTo = "main.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
Here's a test page that DOES work and inserts into a test table:
$InsertQuery->bindColumn("field", "s", "".((isset($_POST["fld1"]))?$_POST["fld1"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("fieldtwo", "s", "".((isset($_POST["fld2"]))?$_POST["fld2"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("sestest");
Any ideas on what could be wrong or tools / examples to echo the Insert query?
i need to see the code in context with the form.
please attach the page rather than the code snippets.
Or a link and FTP info so I can troubleshoot directly.
Steve
ok, give me a bit as I am starting to deconstruct the page to see if any of the prior extensions or sequence is causing the problem.
Steve
moved to private
Steve
clean page will be
http://rivieralaser.com/Admin/photo_insert2.php
I am being redirected to a page that requires login on inserting a record, what is the login?
where is a page that writes all the records from the target table?
Steve
added to private
also, the FTP is not allowing me to make any changes, i need to be able to edit in order to troubleshoot.
Steve
Sorry... FTP permissions updated
something in the tinyMCE implementation is causing the form to not post properly.
i comented this code:
<script language="javascript" type="text/javascript">
/*tinyMCE.init({
mode : "textareas",
theme : "simple"
</script>
and the insert started working.
