File upload
Thread begun 8/18/2014 2:53 pm by rgolab68503 | Last modified 8/22/2014 8:31 am by rgolab68503 | 4723 views | 7 replies |
rgolab68503
File upload
Hi Jason,
Kind of a multiple problem here. I have been struggling with out IT department to change permission on the upload folders to allow for my files to be placed on the server. They kept arguing that the 777 setting is not a "Windows" setting. I'm dealing with that part with them. Needless to say after trying their fixes I have managed to mess my "insert record.php" file to where it doesn't write the names to the designated tables.
To make a long story short I added the error reading code as you asked in a previous site. Below is the error code which I received on this new page which you mentioned that the permissions are not set correctly. Like I said i am trying to get them to change this with a bit of frustration.
First they stated that this code was missing in the form and would fix the issue. enctype="multipart/form-data" and they tested it and say it worked. If i add this code in the form then nothing happens and it doesn't write to the database at all.
If i don't have this code in place then it writes to the database except for renaming the file names to the "AdPicture" text field and writes nothing to the database. Any ideas on why it would not pick up on that name? Is it because the file upload is failing? I believe i have bound default file name to the "AdPicture" hidden text file correctly but did i miss something?
Any help would be very much appreciated.
BTW, when I add the text ... enctype="multipart/form-data" to the form, I get no error message but then again it doesn't write to the database at all.
error code -
INSERT INTO `admatdetails` (`AdProdCode`,`ProductLocation`,`OrderT`,`Ttype`,`Tlanguage`,`Colour`,`AdDesription`,`coop`,`Tname`,`TDesription`,`TdescriptionFR`,`AdPicture`,`AdJPG`,`ADPDF`,`ADZIP`,`published`) VALUES ('test-1-5','','1','G','E','C','A','90','test-1-5 Name','test-1-5 E','test-1-5 F','test-1-5','','','','Y')
( ! ) Notice: Undefined variable: FILES in C:\wamp\www\toyo_dev\Admaterials\admatdetails_insert.php on line 596
Call Stack
# Time Memory Function Location
1 0.0002 369048 {main}( ) ..\admatdetails_insert.php:0
null
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
WA_UploadResult1_2:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
WA_UploadResult1_3:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
WA_UploadResult1_4:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
Status object: WA_UploadResult3
statusCode : 0
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult3_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
Status object: WA_UploadResult4
statusCode : 0
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult4_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
rgolab68503
Server file size
Hi Jason,
After all the fiddling around it ends up being the file size allowed for uploads that was making the file crap out. Everything seems to be working now. Hopefully! :)
the encoding type attribute:
is needed in the form tag, without that there is no way for file upload to work at all.
If that is causing the insert to fail altogether, I Would suspect the size of the files you are uploading, it may be that your uploaded files size is exceeding the max_input_size setting on the server or another of the max form settings,
rgolab68503
Hi Jason,
Thanks for that. We changed the file to include the line, we have the size limit changed to 60 megs but received a timeout message. We raised the time limit to 600 and it seems to go to 100% but we still get this message:
( ! ) Fatal error: Maximum execution time of 600 seconds exceeded in C:\wamp\www\toyo_dev\Admaterials\admatdetails_insert.php on line 1
Call Stack
1 0.0003 370416 {main}( ) ..\admatdetails_insert.php:0
Now I watch the progress of the upload percentage at the bottom of the page and timed it ... after about 45 seconds (files are about 35 megs in total) it reaches the 100% mark (or says 99% ... then waiting for server ...) and then the error message above comes up. Do you have any ideas on what else could be causing this?
As always, your help in this would be appreciated.
"addition"
BTW, I have error logging on and it doesn't write any errors except for the time out error above.
the max execution time for scripts is set to 600 seconds, and it is taking longer than that to upload the file.
add the following at line 1:
<?php set_time_limit(0); ?>
to remove a time limit for execution.
rgolab68503
Thanks jason, I tried this and received the same error.
Call Stack
1 0.0002 370416 {main}( ) ..\admatdetails_insert.php:0
I tested a few other files and seem to be OK up to about 15 megs. This actual test of files I would have uploaded are close to 38 megs. Just wondering if the size is interfering with the upload even though it is set to 60megs.
The problem is the execution time, in other words, the time it takes to upload the file, even though you have it set to allow up to 60 megs, you may not be able to deliver those 60 megs in the time allowed.
With the set time limit:
that should over ride the max execution time setting, but you are still getting the same error and the same report of the execution time being set to 600. this would mean the host has a setting in place preventing you from over riding the execution time. you will need to work with them to have the execution time increased.
rgolab68503
Thanks Jason,
They did find another setting on the server that was defaulted to 60 seconds. Expanded that time limit and now it works!
Have a great day!
