sort order default syntax error
Thread begun 8/18/2014 11:37 am by Christopher West | Last modified 8/18/2014 11:49 am by Jason Byrnes | 1017 views | 1 replies |
Hi I have applied a SORT server behavior (a well as using a search server behavior on same page)
Im trying to get the SORT to default to decending so that the latest record shows at the top of the list. but the DefaultSort parameter in the Sort server behaviour throws an error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Descending' at line 1
Here is the segment on my page that has the SORT server behavior:
//WA DataAssist Sort (Copyright 2007, WebAssist.com)
//Recordset: rsCategories;
$SortThisYear = new WADA_SortObject();
$SortThisYear->DefaultSort "Descending";
$SortThisYear->ColumnList "".$_GET['Sort']  ."";
$SortThisYear->SortOrderList "Ascending";
$SortThisYear->ToggleOn true;
if ((isset(
$_GET['Sort']) && $_GET['Sort'] != "")) {
$SortThisYear->SetToClause $SortThisYear->getDefaultSetToClause();
  if (
$SortThisYear->ToggleOn && isset($_SESSION["WADA_OrderClause_thisyearmanager"])) {
$SortThisYear->ToggleClause $_SESSION["WADA_OrderClause_thisyearmanager"];
else if (isset(
$SortThisYear->SetToClause $_SESSION["WADA_OrderClause_thisyearmanager"];
$SortThisYear->initialize();
$_SESSION["WADA_OrderClause_thisyearmanager"] = $SortThisYear->SetToClause;
Here is my recordset:
mysql_select_db
($database_dinkydb$dinkydb);
$query_rsThisYear "SELECT * FROM orders WHERE Year(OrderDate) = Year(Now())";
setQueryBuilderSource($query_rsThisYear,$SearchThisYear,false);
setQueryBuilderSource($query_rsThisYear,$SortThisYear,false);
$rsThisYear mysql_query($query_rsThisYear$dinkydb) or die(mysql_error());
$row_rsThisYear mysql_fetch_assoc($rsThisYear);
$totalRows_rsThisYear mysql_num_rows($rsThisYear);
Why would it throw an error if I'm simply putting in the default ORDER BY in the Sort server behavior?
Obviously if I place an ORDER BY in the actual recordset then my SORT wont work.
Chris
For the Default Order By Clause, you need to enter the ORDER BY Clause to use by default.
"Descending" is not a valid ORDER BY Clause. nor is it even a fully formed order by clause.
a valid order by clause would be:
ORDER BY columnName DESC
where columnName is the name of the column you want to sort by default.
