MySQLi recordset changes sporadically
Thread begun 8/18/2014 7:04 am by Jason | Last modified 8/21/2014 8:40 am by Jason Byrnes | 9669 views | 36 replies |
Jason
I have a page that contains multiple recordsets (one of which is WADApcms2_users), but for some reason when I make changes or edit any recordest on the page other than WADApcms2_users the code of WADApcms2_users changes and give me an error.
The working code is:
$ParamUserID_WADApcms2_users = "-1";
if (isset($_GET['UserID'])) {
$ParamUserID_WADApcms2_users = $_GET['UserID'];
mysql_select_db($database_local, $local);
$query_WADApcms2_users = sprintf("SELECT UserID, UserEmail, UserFirstName, UserLastName, UserCity, UserState, UserZip, UserPhone, UserCountry, UserGender, UserAddress, UserAddress2, UserDOB, SmallGroup FROM pcms2_users WHERE UserID = %s", GetSQLValueString($ParamUserID_WADApcms2_users, "int"));
$WADApcms2_users = mysql_query($query_WADApcms2_users, $local) or die(mysql_error());
$row_WADApcms2_users = mysql_fetch_assoc($WADApcms2_users);
$totalRows_WADApcms2_users = mysql_num_rows($WADApcms2_users);$ParamUserID_WADApcms2_users = "-1";
$totalRows_WADApcms2_users = mysql_num_rows($WADApcms2_users);?>
The error code that it changes to is:
$totalRows_WADApcms2_users = "-1";
$totalRows_WADApcms2_users = $_GET['UserID'];
if (isset()) {
$ParamUserID_WADApcms2_users = ;
What is causing this and how can I fix it, other than pasting the working code back into the page? The page is attached to this message also.
the code for the WADApcms2_users recordset is duplicated, it should be:
however, you are mixing standard MySQL recordsets with MySQLi recordset, why not just use all MySQLi recordsets?
Jason
I did my best to recreate the query in MySQLi, but I wasn't sure what serveral lines in the original meant. After I'm currently getting the following error, and I don't know what the lines it's referring to are doing (They don't show up in the "Server Behaviors" window). The page is attached.
Notice: Undefined variable: database_local in C:\xampp\htdocs\ALF\public_html\serving\kids\kids_insert_shift.php on line 9
Notice: Undefined variable: local in C:\xampp\htdocs\ALF\public_html\serving\kids\kids_insert_shift.php on line 9
Warning: mysql_select_db() expects parameter 2 to be resource, null given in C:\xampp\htdocs\ALF\public_html\serving\kids\kids_insert_shift.php on line 9
Fatal error: Call to undefined function GetSQLValueString() in C:\xampp\htdocs\ALF\public_html\serving\kids\kids_insert_shift.php on line 10
to convert it to MySQLi, yu remove the entire recordset and recreate the SQL using the MySQL recordset dialog box, that's all that is needed, don't worry about converting the code, just recreate the SQL.
Jason
I followed your instructions (I think) but I'm still getting the same error. Current page is attached.
line 4 - 13:
you still have the old MySQL recordset in place. . .
Jason
Sorry, those were the duplicate lines I forgot to delete again. After deleting those I get this error:
Notice: Undefined variable: row_WADApcms2_users in C:\xampp\htdocs\ALF\public_html\serving\kids\kids_insert_shift.php on line 12
Warning: call_user_func_array() expects parameter 1 to be a valid callback, first array member is not a valid class name or object in C:\xampp\htdocs\ALF\public_html\webassist\mysqli\queryobj.php on line 123
Fatal error: Call to a member function execute() on a non-object in C:\xampp\htdocs\ALF\public_html\webassist\mysqli\queryobj.php on line 124
in the insert, you are using a binding from the old recordset, you will need to use the binding from the new recordset and make sure to move the new recordset to be before the insert.
Jason
It's not giving me the error anymore, but its not actually submitting any data to the database now. After I hit submit it goes to the next page, but when I check the database there's no new entry.
Jason
I added this code back from the previous version:
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
And now it's entering data to the database, but only if the "recurring" checkbox is unchecked, and it's entering 2 identical rows every time I hit submit.
Also, it's no longer inserting the userid into the database, just a 0.
