page redirection based on user
Thread begun 8/18/2014 5:17 am by Jamie | Last modified 8/19/2014 12:25 pm by Jason Byrnes | 6255 views | 24 replies |
Jamie
Hey Jason
Am trying to get this to redirect to a specific page if its specifically a user and another page if it isnt that user. The code isnt working as it takes all users to the news_results page regardless if they have UserID 6 or not.
<?php require_once('../Connections/DBConnection.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
$Users = new WA_MySQLi_RS("Users",$DBConnection,1);
$Users->setQuery("SELECT UserID FROM pcms2_users");
$Users->execute();
<html>
<title></title>
<body>
if ("".($Users->getColumnVal("UserID")) ."" == "6") { // Show If
?><script type="text/javascript">
window.location.replace("product_contents_results.php");
</script>
} // ("".($Users->getColumnVal("UserID")) ."" == "6")
if ("".($Users->getColumnVal("UserID")) ."" != "6") { // Show If
window.location.replace("news_results.php");
</script>
} // ("".($Users->getColumnVal("UserID")) ."" != "6")
</body>
</html>
There is probably a more elegant solution that you may be able to point me in the right direction for?
Cheers
Jamie
CraigRBeta Tester
Hi Jamie,
just wondered if you were using javascript for a reason
would it not be easier using php ?
header("Location: ".redirectURL);
Jamie
No reason at all Craig and have tried your suggestion but it doesnt change the 'result' I'm afraid
EDIT; sorry, it only did the same thing as I had the syntax incorrectly ...
using the php method, I am getting
Warning: Cannot modify header information - headers already sent by (output started at /home/iteacvh1/public_html/admin_cms/index.php:11) in /home/iteacvh1/public_html/admin_cms/index.php on line 28
I have modified the code within the show if statements as follows:
header("Location: http://www.domain.co.uk/admin_cms/news_results.php"); /* Redirect browser */
CraigRBeta Tester
it looks like what your sql statement is doing is returning the first row in the table
Assuming the user is logged in, could you not ditch the recordset and use $_SESSION['UserID']
<!doctype html>
<html>
@session_start;
if ($_SESSION['UserID'] = 6) {
header("Location: http://www.domain.co.uk/product_contents_results.php"); /* Redirect browser */
} else {
header("Location: http://www.domain.co.uk/news_results.php"); /* Redirect browser */
<head>
<meta charset="utf-8">
</head>
<body>
</body>
</html>
Jamie
Thanks Craig...
Am getting this error
Warning: Cannot modify header information - headers already sent by (output started at /home/iteacvh1/public_html/admin_cms/index.php:3) in /home/iteacvh1/public_html/admin_cms/index.php on line 6
CraigRBeta Tester
hmm, shouldn't be anything going to the screen, you could try adding exit();
eg
<?php if ($_SESSION['UserID'] = 6) {
exit();
} else {
exit();
Jamie
thanks but still getting the error
CraigRBeta Tester
can you attache the actual page please ?
code order, you have the redirect after the doctype:
<!doctype html>
<html>
@session_start;
} else {
the redirect should be the first code block:
@session_start;
} else {
} ?><!doctype html>
<html>
CraigRBeta Tester
oops, my bad
