security assist problems
Thread begun 8/15/2014 10:36 am by rpratt89080 | Last modified 8/18/2014 9:26 am by Jason Byrnes | 2744 views | 7 replies |
rpratt89080
When i open the security assist create pages pane my connections say none, when i select my connection by pressing the define button it shows the connection and when i test it it says it was successful but when i press ok it goes back and says conections:none?
Any ideas?
Is your connection a MySQLi connection?
Security Assist is not compatible with the MySQLi connections, you need to use a standard MySQL connection.
rpratt89080
OK, will it be in the future?
The next Upgrade to Data Bridge will include an upgrade to use MySQLi. I don't have a time frame for that though.
rpratt89080
thanks
you're welcome.
rpratt89080
ok, so i have done mysql and i can now see options but every time i try to add session variables or map fields dreamweaver crashes.
I also have everey page missing images
Try uninstalling Data Bridge and installing it again.
if the problem please provide some more details, what is you OS, What version of Dreaweaver?
