Problem creating new insert page
Thread began 8/15/2014 7:19 am by Christian | Last modified 8/15/2014 8:58 am by Christian | 746 views | 2 replies |
Christian
Hello,
I created an "insert" page with Data Assist". Everything when fine until after I hit "finish". I got the following error message:
line 328 of the file
...Configuration/Floaters/WA_ProgreeV2/WA_ProcessingObject.js": newDOM has no properties
and then webassist blocks the progress and Run Time stays at 0:01
What do I have to do in order to be able to create the page?
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
If the problem persists, uninstall Data Bridge from the extension and re install it make sure you have the latest version 1.2.0
Christian
Thanks. I tried your first suggestiong, but it did not work.
Before I go on with reinstalling, I have to say that the Insert Page function worked fine last week. I used it to create another page.
It's just this new page I have been trying to create this week that is causing me problems...
