HTACCESS Friendly URL doesnt work
Thread begun 8/14/2014 11:19 pm by Christopher West | Last modified 8/19/2014 7:09 am by Jamie | 5765 views | 18 replies |
Hi , I understand this maybe out of scope on support. but wondered if its possible that anyone can help as I have trailed through websites and tried different approaches.
I would like to change the URL (for example)
http://www.dinkyfingerprintjewellery.co.uk/category.php?Categories=Cufflinks
TO
http://www.dinkyfingerprintjewellery.co.uk/Cufflinks/
I thought this line of code would do it, but it just displays my normal URL
RewriteRule ^([^/.]+)/?$ category.php?Categories=$1 [NC]
its the htaccess file in context...
in my htaccess file I am using the following:
RewriteEngine on
RewriteCond %{HTTP_HOST} !^www\.dinkyfingerprintjewellery\.co.uk
RewriteRule (.*) http://www.dinkyfingerprintjewellery.co.uk/$1 [R=301,L]
Options +FollowSymlinks
Options -Multiviews
RewriteCond %{HTTP_USER_AGENT} libwww-perl.*
RewriteRule .* – [F,L]
Jamie
Hey Christopher
Not sure about the path that you have suggested (its something I have in my 'to do' list to talk to Ray about' but I use this the following structure on all my dynamic pages - couple of examples: check out the news article links on http://www.ybg.org.uk/news.php or the member links on http://blandfordbusiness.co.uk/members.php
This is how I put it together (and using your suggested domain):
Addition of <base href="http://www.dinkyfingerprintjewellery.co.uk/" > to the target page
Recordset structure (on target page category.php):
(You need to change $RSName, $DBConnection, table_name, Permalink and KeyColumnID to your own references)
$RSName = new WA_MySQLi_RS("RSName ",$DBConnection,1);
$RSName ->setQuery("SELECT * FROM table_name WHERE KeyColumnID = ? OR Permalink = ?");
$RSName ->bindParam("i", "".(isset($_GET['id'])?$_GET['id']:"") ."", "-1"); //paramOffersID
$RSName ->bindParam("s", "".(isset($_GET['perm'])?$_GET['perm']:"") ."", "-1"); //paramPermalink
$RSName ->execute();
Where the difference lies in what you have put, is the addition of a faux 'folder' in the URL structure
Where you have put:
I would add a faux folder like this:
http://www.dinkyfingerprintjewellery.co.uk/folder-name/Cufflinks/ (note the addition of /folder-name/ to the structure)
Your raw URL is http://www.dinkyfingerprintjewellery.co.uk/category.php?Categories=Cufflinks
so the htaccess that pulls it all together is
RewriteEngine on
RewriteRule ^folder-name/(.*)$ category.php?perm=$1 [NC,L,QSA,T=application/x-httpd-php]
and all you need to do to link to that page is use the structure like ttp://www.dinkyfingerprintjewellery.co.uk/folder-name/Cufflinks/
Hope this helps?
All the best
Jamie
Hi Jamie, at the moment my site isnt using mysqi and just want to keep things consistent if that makes sense. PLus would rather refrain from adding to the code in php. What I would like to find out is why my htaccess only method doesnt work. since after looking up various websites the code in htaccess that I am using is the same (there are no errors on the page) its simple just has no effect., and i tried slightly different variations and again has no effect. so I cannot understand why so so many users are using this code and yet when I do nothing happens...what is stopping it from functioning? I know the actual htaccess file is ok since I have other directives in there to redirect www and non www.
Chris
Jamie
Totally understand.
In case it helps, this would be the msql version for the RS
$colname_RSNamePerm = "-1";
if (isset($_GET['perm'])) {
$colname_RSNamePerm = $_GET['perm'];
$colname_RSName = "-1";
if (isset($_GET['id'])) {
$colname_RSName = $_GET['id'];
mysql_select_db($database_DBConnection, $DBConnection);
$query_RSName = sprintf("SELECT * FROM table_name WHERE KeyColumnID= %s OR Permalink = %s1", GetSQLValueString($colname_RSName, "text"),GetSQLValueString($colname_RSNamePerm, "text"));
$RSName = mysql_query($query_RSName, $DBConnection) or die(mysql_error());
$row_RSName = mysql_fetch_assoc($RSName);
$totalRows_RSName = mysql_num_rows($RSName);
mod_rewrite is not my strong suit so i cant really offer a lot of assistance on this one, you would probably get better help posting to the webmaster world forums or another forum more specific to mod_rewrite.
however, i think you need a leading forward slash in your rule:
instead of
try:
RewriteRule ^([^/.]+)/?$ /category.php?Categories=$1 [NC]
Hi Jason, I tried that it has no effect. interestingly I know if you do the slightest mistake in HTACCESS that it completely stops the website working..in my case the website is still accessable which means that syntax is playing friendly. I will check out those forums you mentioned.
Also Jamie, I will try your php method on my testing server which will give me more time to experiment. Im just cofused why it cannot work simply by htaccess only method like most users use on the web that I have seen.
Also Jamie, if you know any more on htaccess.Im trying to get Firefox's YSLOW to have a better score, currently I have a score of 82..but this will be a lot higher soon as i upgraded my 1and1 hosting which now supports CDN hosting via cloudflare. which means GZIP and Use a Content Delivery Network will get a score of "A"
the only parts that I score low on are :
Add Expire Headers (Scored F)
Configure Entity Tags (ETags) (Scored D)
I have this snippet of code fr htaccess and wondered if correct as it has no effect on my score if I place this code in:
(also I believe it screws up my CSS file, when I installed it earlier my CSS was wiped..possible cause last night I minified my CSS file and it screwed up the website for some reason...so perhaps it was stilll caching that minifed version).
<ifModule mod_expires.c>
ExpiresActive On
ExpiresDefault "access plus 1 seconds"
ExpiresByType text/html "access plus 1 seconds"
ExpiresByType image/gif "access plus 2592000 seconds"
ExpiresByType image/jpeg "access plus 2592000 seconds"
ExpiresByType image/png "access plus 2592000 seconds"
ExpiresByType text/css "access plus 604800 seconds"
ExpiresByType text/javascript "access plus 216000 seconds"
ExpiresByType application/x-javascript "access plus 216000 seconds"
</ifModule>
<ifModule mod_headers.c>
<filesMatch "\\.(ico|pdf|flv|jpg|jpeg|png|gif|swf)$">
Header set Cache-Control "max-age=2592000, public"
</filesMatch>
<filesMatch "\\.(css)$">
Header set Cache-Control "max-age=604800, public"
</filesMatch>
<filesMatch "\\.(js)$">
Header set Cache-Control "max-age=216000, private"
</filesMatch>
<filesMatch "\\.(xml|txt)$">
Header set Cache-Control "max-age=216000, public, must-revalidate"
</filesMatch>
<filesMatch "\\.(html|htm|php)$">
Header set Cache-Control "max-age=1, private, must-revalidate"
</filesMatch>
</ifModule>
Header unset ETag
</ifModule>
FileETag None
Just FYI Chris, if I use:
without the trailing slash, i get the proper result. . .
Hmm...now im confused lol so would this mean that Google or any other search engine would now index this page as http://www.dinkyfingerprintjewellery.co.uk/Cufflinks or would it still only use the ones that are hardcoded in my page navigation links?
Also I think my CDN is messed up as if I do put the trailing slash at the end it displays the website but without any CSS either that or its my a conflict in the HTACCESS?
here is the complete htaccess if anyone would know why the css doesnt show. All I can think is that the CDN is caching the working CSS for the moment.
RewriteEngine on
Options -Multiviews
ExpiresActive On
ExpiresByType image/jpg "access plus 1 year"
ExpiresByType image/jpeg "access plus 1 year"
ExpiresByType image/gif "access plus 1 year"
ExpiresByType image/png "access plus 1 year"
ExpiresByType text/css "access plus 1 month"
ExpiresByType application/pdf "access plus 1 month"
ExpiresByType text/x-javascript "access plus 1 month"
ExpiresByType application/x-shockwave-flash "access plus 1 month"
ExpiresByType image/x-icon "access plus 1 year"
ExpiresDefault "access plus 2 days"
# Turn ETags Off
Header unset ETag
</ifModule>
FileETag None
Header unset Last-Modified
</ifModule>
search engines will only use the links in your site for indexing.
you would need to change the links in your site and resubmit a site map to the search engines for them to change the way the page is indexed.
ah and use Jamie's php method would solve this :)
