ecommerce question
Thread begun 8/14/2014 3:46 pm by Webbie | Last modified 8/26/2014 6:53 am by Jason Byrnes | 5061 views | 15 replies |
Webbie
ecommerce question
Jason,
I am wanting to add another select list into my product details page and Just want to check before i do anything,
I have to adjust my ecart object, then update my shopping cart, then add the product option recordset, then do the add to cart button again.
If i go through this process will this mess up my gateway portal and paypal information that i already have set up?
Or is there a more simple way to do this, like copy and paste the php code, add a recordset then point that to the select list?
Just want to make sure if i should go through the whole process or not just to make one more select list, my database is alll ready for it.
Thank you
add the new column to the cart object, create the new option recordset. edit the add to caret buttons to add the new option select list and edit the cart display to show the new column should be all you need to do.
Webbie
Got the add to cart button adjusted, record sets done, populated the new select list, and adjusted the shopping cart.
Problem im having is when i click on checkout from the detail page to go to the shopping cart i get a blank white screen, i used that code you gave me to turn on errors and put it into the template page for problem page, did not work.
The problem page is : http://ewebsolutionsinc.com/buy_package_detail.php?ProductID=108%20&pageNum_WADAProducts_3=5
It seems it will not go to the products_cart page where shopping cart is...
Any idea why its going blank and wont display error's? How can i fix this?
Talk to ya Monday,
error reporting needed to be on the product_details.php page. it shows:
Notice: Use of undefined constant ServicePrice - assumed 'ServicePrice' in /home1/ewebsol3/public_html/ewebsolutionsinc/WA_eCart/eCartEWEB_PHP.php on line 208
Fatal error: Unsupported operand types in /home1/ewebsol3/public_html/ewebsolutionsinc/WA_eCart/eCartEWEB_PHP.php on line 208
This is caused by the total price calcualtion, in both total price and tru price, you refe to the [ServicePrice] column. that column does not exist, it is named ServicePriceInc, not ServicePrice
Webbie
Ok thanks,
Yes that makes sense because serviceprice is just the name of item and servipriceinc is the actuall price increase that goes on the cart. Got it.
Where is that again?
Do i edit that in ecart object or edit cart from recordset?
it is in the calculations in the ecart object.
Webbie
Thanks Jason,
I got the checkout cart working.
My checkout button on the cart page does not take me to the payment gateway page it just reloads.
Any ideas whats happening here?
there is no redirect set for the checkout server behaivor.
The checkout button code is at line 43 - 61:
//WA eCart Redirect Check Out
if (isset($_POST["eCartEWEB_Checkout"]) || isset($_POST["eCartEWEB_Checkout_x"])) {
$Redirect_redirStr="";
if ($Redirect_redirStr != "") {
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") === false) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$eCartEWEB->redirStr = $Redirect_redirStr;
$eCartEWEB->cartAction = "Checkout";
edit line 46 of the cart page:
to set the redirect for the checkout button.
$Redirect_redirStr="checkout.php";
Webbie
Thanks,
Do you know how i can create a blank spot in the dynamic drop down list for products so customers have the option of not purchasing some of my addons?
add a blank option:
<option value=""></option>
