Quote form
Thread began 8/14/2014 6:34 am by saf01 | Last modified 8/19/2014 11:53 am by Jason Byrnes | 4218 views | 18 replies |
saf01
Quote form
I made a form with several fields, when submitted, displays what you submitted on the next screen - this is the form's action php page.
This works fine. Now the issue is this:
I want to make the form also submit values entered into a database (the database is created already). When I add MYSQLi insert record behaviour to the form and change the form's action page to itself, then change the insert record gotopage to the actual action php page, the quote values don't appear on the screen, but the form values are entered into the database. If I change the form's action to the actual action php page and then leave blank the insert record gotoPage, then the values are displayed on the action page but no values are added to the database.
If I add the insert record behaviour to the actual action page, it works, but everytime I refresh that page it adds new values to the database.
On the action page, Im using the following code to show values on screen:
foreach ($_POST as $key => $value) {
$$key = $value;
If (empty ($value1)) {
die( 'Error !' );
If (empty ($value2)) {
$value2 = "value2";
If (empty ($value3)) {
$value3 = "value3";
Please can you tell me what's the best way to show values on the screen and insert them into the database.
change the trigger for the insert record behavior to Any form post.
saf01
Thanks, done that. Still inserts a new record on page refresh of the action page. Is adding the insert behaviour on the action page the right place to have it? Adding the insert behaviour on the form page it works if the form page doesn't have any action. But then the screen printing of what is submitted doesn't appear on the action page.
So how do I display the values added from the form page to appear on the action page using MYSQLi behaviour?
If the Form page has a form field: <input name="value1" type="text" id="value1" size="40">
How to display this form field print on the action page?
Please help.
all form processing must occur on the action page.
you have 2 options:
1) set the action page to be the same page as the form
add the insert on that page.
in the insert behavior, there is an option to save the new record ID to a session variable
set the insert to redirect to another page, and use the session in a recordset to look up the inserted data and display it from the recordset
2) Set the action to go to the other page, add the insert on that page and use the form bindings there.
if the page is refreshed, it will resubmit the form though. this wont happen if you use option 1.
saf01
Thanks again. I followed option 1 and its working, I see the values entered and it inserts - I added recordset filtered by session variable to display.
I have another question, how do I do a calculation e.g: recordset_value1 + recordset_value2 and display it. Another example would be a dropdown form field value on the form page:
If ($Recordset1->getColumnVal("value1") == '500 - 999') {
$myquote = 200;
If I run this on the browser, it gives undefined variable myquote. I want to display myquote as 200 if the dropdown selected is '500 - 999'
Please help with this final one.
add the bindings for the 2 columns to the page, then post the binding code here, and i can show you how to add them together.
saf01
ok. Here are my two bindings:
<?php echo($Recordset1->getColumnVal("area")); ?>
<?php echo($Recordset1->getColumnVal("design")); ?>
Area is selected from a dropdown on the form page, then displayed on the action page. Design is also selected from another dropdown on the form page. For example:
If area dropdown is: '500 - 999' then $myquote1 value is 200
If design dropdown is: 'Shop Front' then $myquote2 value is 100
$TotalQuote = $myquote1 + myquote2 <------ I wish to display and do this calculation
Thanks for your help.
use this:
<?php echo($Recordset1->getColumnVal("area") + $Recordset1->getColumnVal("design")); ?>
saf01
Thanks Jason. Thats great, appreciate it.
saf01
I wish to add form validation now. Is WebAssist server validation ok to use with mysqli insert record behaviour on the form?
Please advise.
